Question about Epson Perfection 4870 PHOTO Scanner
Cant get it going ,uninstalled driver, new install (macmini)
Uninstalled driver, reinstalled macmini still does not recognize the scanner epson 4870
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Please try to repair the operating system or reinstall the operating system then try the driver again
Posted on May 27, 2009
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Epson stylus cx7800 scanner distorted line running top to bottom
The drivers that are compatible with windows 2000 works with win xp too.
If you want to get the epson scanner driver for the cx7800 that is compatible with win xp, please log on to support.epson.com. click on all in ones to the left of the page. Then click on flatbed under all in ones. Click on Epson Stylus cx7800 under 2.Then select your product to the right of the page. Click on Windows under drivers and downloads. Click on the 8th driver down which is the epson11577.exe, it says TWAIN Driver and EPSON Scan Utility v2.73A, then click on download now. click on thanks i prefer not to receive this information then click on the accept button. Click on direct link to the file then run the driver.
NOTE: make sure that the scanner is off and unplugged from your computer while you're downloading the drivers.
Do not forget to uninstall the drivers too before you install the new driver.
To uninstall driver:
- Click on start.
- go to control panel
- go to add or remove programs
- highlight epson scan then click on change remove and just go ahead and remove the driver.
- then restart your computer.
- download the driver once your computer is fully booted up.
May 12, 2009 | Epson Perfection 4490 Film / Flatbed...
EPSON Perfection 4870 Photo Scanner - Driver for vista
Kindly check out the URL and you will get the driver http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=28461&infoType=Downloads
Dec 14, 2008 | Epson Perfection 4870 PHOTO Scanner
Can't use the ''Film selection on epson V700
Make sure the transparency light cable that comes from the lid is plugged in to the back of the scanner. If the cable is unplugged for any reason, the transparency/film options will not be available.
Nov 18, 2008 | Epson Perfection V700 PHOTO Flatbed...
Help me pleaze
check if it connection issue
check all cables if it is connected directly
check device manager for imaging device see if there is a conflict update the driver
if same hotswap, then try another cable
if connection ok then same issue
trash and reinstall and reinstall the epson scan: follow this
Scanner Driver Removal
If you see a window that says User Account Control at any point, click Continue.
  1. Disconnect the USB cable from the printer and close any open windows.
  2. Click Start, then select Control Panel.
  3. In the window that opens, click Uninstall a Program under the Programs heading.
  4. Select Epson Scan, then click Uninstall/Change.
  5. Follow the on-screen instructions to complete the removal and restart your computer.
Once the removal is complete, please do the following:
Scanner Driver Download
  1. Go to www.epson.com select your contry
  2. Under All-In-Ones, select Flatbed, then select your model from the list.
  3. Click on Windows under Drivers & Downloads.
  4. Download the most current version of the Scanner Driver for your Windows operating system to your Desktop. Make a note of the file name in order to easily retrieve it.
Scanner Driver Install
  1. Double-click the downloaded file on your desktop.
  2. Click OK, Unzip, then OK again.
  3. Follow the on-screen instructions to complete the installation and license agreement. The installer will copy the files to the system.
  4. Click Finish when prompted.
  5. Turn your unit on and reconnect it to the computer after the installation is complete.
  6. Windows should detect new Hardware and complete the installation automatically.
  7. If a New Hardware Wizard appears, allow it to search automatically.
  8. If a message appears indicating The Scanner has not passed Windows Logo testing, click Continue Anyway. Then click Finish.
  9. Restart your computer before testing the scanner software.
Oct 09, 2008 | Epson Office Equipment & Supplies
Epson Expression 1680
Hi-
Do you have any existing drivers for new epson scanners( models), if you have then there are compatibility issues between new drivers and old drivers, are you using a leopard 10.5 operating system or tiger 10.4.**? try uninstalling every epson info from applications folder and from library/image capture and library/preferences. you an use the finder to search for epson scan and drg them all to trash. Try using image capture application as well if it will scan when you run it, then reinstall driver.
One more thing, when you click on epson scan, does it bounce continouosly from the dock? if it is then look for a subfolder and install everything in it.
Keep me posted, thanks!
Aug 27, 2008 | Epson Expression 1680 Flatbed Scanner
Is not recognized by other programs and won't let me re-install
Do one thing go for the web sites of your scanner and download the driver and software of your o/s.
Jun 03, 2008 | Epson Perfection 1660 Photo Flatbed...
Epson CX 3200 - twain error scanner not recognized
Click HERE for a troubleshooting guide
Click HERE for drivers and documentation
May 26, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
Scanner Not Recognized
You need to remove the yellow question mark on the device manager. Click on the plus sign of the Question mark icon. Right click on the item that will be displayed under the question mark and then uninstall. You need to uninstall the drivers as well. you can doo it on add/remove programs(winxp) or program features (vista). Unplug the USb cable/ Download drivers from support.epson.com and you just need to choose the right driver for your windows version. After Installing the TWAIN driver and Epson scan utility, you need to restart computer. When computer is ready you can plug in the usb cable and open up Epson Scan on your desktop
Jan 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Perfection 4870 PHOTO Scanner Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
