Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works; fridge side doesn't
The freezer is working fine.  The refigerator side is not working at all, though it was working fine.  There is very little cold air coming through the vent even though I have turned the cool setting all the way up.  The air in the freezer is coming through full force.  Any suggestions?  Thanks in advance.
  • 1 more comment
  • Anonymous Feb 17, 2009
    I have the same problem, my refrigerator side isn't working but my freezer is working.
    My refigerator door was staying open alot of the time until I repaired the closing cam. Now it isn't staying cold
  • ksdasher Feb 21, 2009
    freezer is working fine. Fridge is maintaining temperature of 50 degrees. Cleaned the coils and there is no frost on the left side. Even turned down the temp control in the fridge but it maintains 50 degrees. What could be the problem???
  • Anonymous Mar 22, 2014
    ice maker also works, some cold comes thru vent from freezer to fridge side
  • 473 Answers
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Posted on Oct 21, 2007
It is a frost build up what to do now ?
Posted on Jan 08, 2008
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
I have a Kitchenaid KSCS20QFAL01 refrigerator. The freezer side gets cold but the refigerator side does not. The difuser has been replaced but did not solve the problem. It was working fine until the...
clean all the dust off the coils on the back of the fridge and all the dust out from underneath the fridge. This was the cause of my fridge not cooling and it worked and cost me to have somebody come out to blow all the dust out from underneath. Give it a try
Jul 24, 2010 | KitchenAid Refrigerators
I have a monogram ZIS420 the freezer works fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Frezzer working fine, but fridge very warm what do i do
if the technician says you need a defrost heater, then it should be replace for the refigerator to work perfectly.
Jun 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Side by side..fridge is freezing up while freezer works fine
Your baffle that controls the freezer temperature is possibly broken.  If you take the cover off the dials labeled "refrigerator/freezer" the baffle is a plastic arm that controls the amount of air circulation between the freezer and the refigerator. If the arm is broken is will stay closed completely blocking the air hole or vent.  I just wedged a small piece of wood or shim in mine and it hasn't frozen up since.
Good Luck.  I know how frustrating it can be to repeatedly defrost the ice build-up.
Mary Lynn, Alabama
Oct 11, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
283 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
