Question about Scunci 52067 Handheld Steam Vacuum
The steamer will not shut off even when the plunger is not depres
Was having problems with the steamer. The valve is working fine now, but the steam will not stop when the handle is not being depressed.
  • jroode55
    jroode55 May 16, 2012
    I had a similar problem w my Steamfast. Fixed by dismantling and spraying handle-valve w wd40.
  • Anonymous Mar 18, 2014
    the tank cap center button is depressed
    steamer will not steam & then the center tank cap button is depressed
    Sergeant:
  • 199 Answers
Your valve might be gone to much use or mechanism of the handler broken
Posted on May 28, 2009
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
I am having problems with my Delonghi Magnifica espresso maker. It is leaking steam when the knob is shut off. It also leaks steam from the vents on the side after using the steamer. It takes several...
To solve leak problem you can follow these links " http://www.homeespressomaker.org/2-delonghi-magnifica-espresso-machine-leaks-and-leak-problem-fixed/", " http://delonghimagnificaespresso.info/saeco-italia-espresso-machine-leak/". Hope these will help you.
May 31, 2011 | Vacuums
My Shark steamer works fine for a few minutes and then the steam doesn't come out anymore.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Dec 07, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have an electrolux enviro multi steamer and have no instructions. I filled it up and turned it on and it is steaming out everywhere. The handle became too hot to use. What am I doing wrong ?
Check the handle. There is a Button which you press and hold and one which slides up and down. The slide button is so you don't have to depress the other button (when you are wanting constant steam, ie., for cleaning floors etc...).
I would suggest that the slide button is engaged (meaning in the on position), slide it back the opposite way and see if this solves the problem. Regards, Tina
Nov 15, 2009 | Electrolux Vacuums
I broke the handle part of the shark steamer #53101. I don't have the book to try to tell you the parts I need. Can you send me a picture or a copy of the steamer. It is purple. The above number may not be...
Ann there are very few parts for these...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
SC505H Portable Steamer with broken hose in the handle
I also have the Shark steamer worked great for a while lots of pressure but then pressure started coming out of the insert part for the wond not sure if its the o rings that need replaces or just the wond it self can any one help me
Jun 24, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-pro model EP923H Steam Valve
I suspect you have done something on this by now but . . . You need to pry out a plastic cap/insert in the top of the handle. Beneath it are 1-2 screws to remove. The halves will then come apart. I have mine broken down but have no idea what to do now. It is not making steam. Reply if you have any thoughts.
Keith
Apr 08, 2009 | Euro-Pro EP923 Canister Steam Vacuum
Steam won't shut off
I have portable steam sharrk, had same problem. I filled it with water and now works fine, water level might be to low
Jan 07, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Steam and water both comming out
Try not to overfill it, and try again. If the level is fine, there may be a break internally or problem with the valves not operating correctly. Both need dissasembly to find out.
Hope this helps.
Thank you for using Fixya.
Dec 26, 2008 | Scunci 52067 Handheld Steam Vacuum
Scunci 52067 Handheld Steam Vacuum Logo
340 people viewed this question
Top Scunci Vacuums Experts
Craig Butler
Craig Butler
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
