Question about KitchenAid Dryers
The drier has no heat.
Our heat is not working on the Kitchen Aid Superba gas drier.
I have a repairman scheduled for tomorrow.
Thank you for the followup.
Posted on May 28, 2009
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba oven is getting a error code of: F3-E0 the temperature won't go over 250
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 29, 2010 | KitchenAid KGRC608LSS Gas Kitchen Range
I have a kitchen aid dryer SUPERBA electric dryer. It stopped drying. still runs ok but no heat. Checket the Element . looks fine . what could be the reason.?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen aid kgys750gq0 works but there is no heat
The KitchenAid KGYS750GQ0 is a gas dryer, so the solution of looking for a heating element is not helpful. There are several heat switches and a gas burner assembly (which includes a gas valve and an electric ignition), any of which could be the problem.
May 15, 2010 | Dryers
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Ignotor problem on kitchen aid superba
if it takes that long its either the spark moduel or the sw / if all the burners do the same replace the spark moduel and if only one does this replace the sw . some sw kit require all sw tho be repl as they come in a harnes. pre wired. mm hope this helped / feed back pls ..
Feb 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
My mother has a Kitchenaid Superba Dryer, gas, everything seems to work, but the unit won't heat.
WELL ITS 1 OF A COUPLE OF THINGS NO HEAT KITCHEN AID USES A THERMAL FUSE IN THE BACK OF THE DRYER CHECK THAT FIRST USE A MULTI METER FOR THAT ALWAYS UNPLUG ANY APPLIANCE WHEN DOING ANY WORK ON THEM IF YOU HAVE A GLOW DOWN ON BOTTOM IT COULD BE THE FLAME SENSOR IS BAD OR GAS VALVE COILS ARE NOT LETTING THE GAS OUT OR YOUR GAS IS OFF AT MAIN FROM HOUSE GOOD LUCK GEORGE
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid range heats up too slowly
Take the element out and check the ohms on the element. Replacing the element will fix you up.
Nov 16, 2008 | Kitchen Ranges
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Open Questions:
Dryers Logo
87 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
