Question about Vacuums
Tube to Fantom Thunder canister blocked
I know where the blockage is, I just can't get to it. How can I clear out the blockage to the canister without tearing down the vacuum? The blockage is in the tube that sits behind the canister and is preventing dirt from going in the canister. I tried to use a paper clip but it was too flimsy.
I cut a strip of window screen about 1 inch wide and 12 inches long and slid it up the tube from the back of the vacuum. The screen edges grabbed the gunk and as I pulled the screen strip out from the tube the gunk came with it, clearing the blockage.
Posted on May 28, 2009
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
Dec 11, 2012 | Eureka True Clean Upright Vacuum (Yellow)...
Fantom thunder vacuum owners manual
Heparrest has the manual to the Fantom Thunder here: http://www.heparrest.net/Fantom_Thunder.pdf . You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 17, 2011 | Vacuums
Where can I get a manual for a Fantom Thunder vaccuum model # F12052 00?
The manual for the Fantom Thunder is available here: http://www.heparrest.net/Fantom_Thunder.pdf . If this direct link doesn't work, start here: http://www.heparrest.net/SuggestedMaintenance.html and scroll down to the Fantom Thunder.
I hope this helps.
May 19, 2011 | Vacuums
Hi, i've had my dirt devil for a couple years now and till a month ago its held up well. we have wood floors in our house and only use it on the scatter rugs but last week it stopped picking up debris. i...
Detach the hose at both ends. Drop a coin or marble down one end. If it rolls free, the hose is okay. If not, the hose is clogged. To clear it hold the wrong end of the hose to the tank and turn on. The reverse suction should clear the blockage. If not, try pushing it clear with a broom stick.
Check the power head where the hose attaches. Drop a coin down from the top. If it gets stuck, there's a blockage there. Try to clear it by pushing the handle of a wooden spoon or similar dull item down to push it clear.
Depending on the noise the vacuum is making, it's also possible some dust/debris got into the motor, causing problems.
Jan 12, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Looking for the wand for the fantom lightin canister vacum, anybody know where I can find one.
they have gone out of business so I would check on craigs list and used vacuum stores.
Oct 07, 2010 | Fantom Vacums Lighting Canister Vacuum
No suction once hose is plugged in. If I go to another recepticle it has plenty of suction until I plug the hose in. I just bought this house and the owner was unable to help with operating manuals due to...
If it's just the one outlet, then there's probably a clog in the pipe between that outlet and the main pipe. You may be able to clear it by plugging the hose into a working outlet, placing other end to non-working outlet, and turning vacuum on. This may provide enough suction to **** out the clog.
If not, you'll probably need to use a mini plumber's snake to try to remove it.
Sep 11, 2010 | Broan-NuTone CV353 Central Vacuum
Cant find one
Hello. You can call the Fantom company directly at 800-798-7395. Or use their website http://www.fantom.com/fantom/default.aspx
please rate my answer as very helpful. thanks. Joe800-800----
Apr 21, 2010 | Fantom Vacums Lighting Canister Vacuum
My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Nov 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Bissell powerforce bagless vacuum,when turned on dust flies out sweeper
Dust flying out of the sweeper indicates that their is a blockage in the pathway that the dirt normally travels to get into the dirt collection chamber. Turn the sweeper upside down and look for a blockage of some kind. Also, empty out the canister and look to see that the pathway into the canister is clear.
May 18, 2009 | Vacuums
Vacuums Logo
236 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
