Question about JVC Silver DVD Digital Theater System - THC7 System
JVC DVD Digital Theatre System TH-C3 ? WON'T POWER ON!
I've had the system for a couple years and it's worked perfectly up until the other day. I recently moved (taking all electronic components with me in the car - they were handled carefully) and after I had hooked everything back up, I went to turn on the JVC and nothing happened. It's completely dead. I've tried different cords and several outlets to make sure that is not the issue. When I plug it into a NEW outlet, the light comes on for a brief second, then goes out (subsequent plug-ins to the SAME outlet will produce no result unless some time has passed). It will NOT power on at all. Nothing has happened to the system, and as I said, it worked perfectly fine up until it was unplugged for the move!
Any ideas?? Is this worth paying to repair? Meaning... how does the cost of repair compare to just buying something new? I'm having a housewarming party this weekend and pretty bummed that I'll have no music for it... :(
3 Suggested Answers
SOURCE: JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Posted on Sep 20, 2007
dragonsthatk
  • 547 Answers
SOURCE: Can't get jvc th-c60 to turn back on
check fuse
Posted on Feb 19, 2009
How do I get a disc jammed out of my JVC theatre digital TH-C5 theatre system step by step?
I can't see any procedure for removing any disc. So your best option is to open the unit containing the disc up and remove it manually. If your lucky you should see a belt that will slide the drawer out. If you have doubts then take it to the nearest JVC repair shop.
Nov 25, 2016 | JVC TH-C5 System
I have a (jvc dvd digital cinema system th-s3). that will not play original dvds however it seems to play copies and cds just fine in fact all other functions work correctly. i have tried a lens cleaning...
I have the same system. I've had no trouble until a year ago, then the system got particular about when it wanted to play DVDs. I've also used lens cleaner to no avail. It plays some DVD's but plays all CD's and some copies. It has given me good service but cost me a lot of money. I hope there is a simple solution to this.
May 17, 2011 | JVC TH-S3 System
Listen to DTV DVR output on TH-C3
im not familiar with this model. can i assume it is a small home theatre system with limited inputs?
in that case, the best thing to do is to feed all your devices...cable, dvr, dvd, etc....into the tv.(audio and video). then use the audio output of the tv to the input on the receiver. you may have to go into the tv menu and set the audio output to the speakers in the tv to fixed mode for a constant level out to the receiver.
good luck
Dec 08, 2009 | JVC TH-C3 System
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
The cable that connects my JVC DVD player to surround sound power speaker has bent pins. dvd Digital theatre system th-a10
Use a bird beak pliers and gently straighten the pins out, A small bladed screw driver may assist in seperating the pins. Try getting them as close to possible as perfect. Be very careful when doing this as to much bending will break the pins. In that case you will eighter need to HARD WIRE it of possibly get a new one.
Jul 10, 2008 | JVC Televison & Video
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
Color Gone
check and see if your dvd player is not on pal if it is then you switch to ntsc.if it is not on pal then check all your connections if every thing is okay its time to call in the tech the dvd is having a problem in the video circuit.good luck.
Apr 16, 2007 | JVC THC3 Home Theater System System
JVC Silver DVD Digital Theater System - THC7 System Logo
128 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
