Question about GE Refrigerators
My GE refrigerator is no making ice
My GE refrigerator is coolong but is no making ice. Last weekend the ice counter was full , then I turned the icemeker off, and I realized next morning I had let the freezer door a little bit open. I took out de ice and turned the ice maker on, but after that it's no making ice
  • GE Master
  • 4,654 Answers
Please send me the model number locate in places in photo below. This way I will be able to help you better, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 27, 2009
I have a GE refrigerator, model TPX24BPDA, that has an ice maker that won't stop making ice! Whatever mechanism that senses when the hopper is full isn't working. I can't locate any sensor either.
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Oct 05, 2016 | GE Refrigerators
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    My side by side fridge freezer is leaking especially at night. Thanks
    Wrong setting of thermostat/malfunction of thermostat/drain line blocked by dust or ice cubes.
    Keep setting @5degree/ check thermostat is shuts off fridge by turning counter clockwise. If not replace thermostat./Due to over frosting drain line plugged with ice debris or full of dust. Clean the drain line. Helpful?
    Feb 01, 2011 | GE Refrigerators
    Amana, bottom freezer, freezer not freezing and then refrigerator not keeping cool.. help Started with the ice maker not making ice, the sound of trying to pull water but never any ice. Then the freezer,...
    Hi
    Firstly put off the refrigerator before the compressor burns off.
    The problem is simple... the coling gas has leaked out.... put new coolong gas...BUT only after finding the place of leak... this will be needed to be fixed first.
    Regards
    Berry
    Feb 07, 2010 | Amana ABB1927DE Bottom Freezer...
    My fridge keeps freezing my food
    The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
    The problem could be the electronic control if you have one or the mechanical linkages.
    Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    The Icemaker is not working
    When the door was open thawing and freezing occurred and your ice maker is now frozen up. there may even be ice in the water line feeding the ice maker.
    Empty the entire side by side and unplug it for 24 hours with both doors open. This will solve your problem.
    Your cold and frozen food will have to be stored elsewhere during this process so nothing spoils.
    May 28, 2009 | GE GSS22JERBB 34" 21.9 Cu. Ft....
    GE refrigerator not cold enough, again!
    I emptied the freezer, unscrewed the freezer floor, pushed it out of the way, and saw the ice, just like last time. So I poured hot water over the ice, made sure the ice was all melted, even from below (under refrigerator), and put the floor back in - works fine, for now!
    Jul 13, 2008 | GE PTC22MB Top Freezer Refrigerator
    Freezer not working!!!
    did you know that hot water freezes quicker than cold water you can try this
    the reason for this is scientific
    the molecules in the hot water are moving faster than colder water thats why hot water freezes faster
    that was a little quote i picked up from science magazine
    i have read over the fixya site several people have had the same problem with this particular model so i am only going to pass on what has been discused in fixya in hopes that this will help
    the thermo controls are malfunctioning
    or your fridge is leaking freon from one of its copper lines fix accordingly even with a refrigeration tech
    Jun 09, 2008 | GE GSS20IEP Side by Side Refrigerator
    Refrigerators Logo
    62 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
