Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
White lines will not go away in our Xerox C2424
We are working on a Xerox Workcentre C2424, trying to eliminate the white lines in the print. We have removed and cleaned the printhead, cleaned all the Wiper Blades and performed all the onscreen cleaning procedures as directed. Help......
  • Frank Zhang
    Frank Zhang May 11, 2010
    white line goes vertical or horizon? what thin look like?
    President:
  • 2,072 Answers
Since you have done all that. That tells me you almost certainly have a bad print head.
They will clog or sometimes the jets get damages and it becomes impossible to pass ink through them.
I would say a bad print head is about a 99 percent probability.
Posted on May 28, 2009
  • Xerox Expert
  • 393 Answers
If the white lines are not too bad use jet substitution, this will slow it slightly but cheaper than a print head.
-Carl, please let me know if this helps.
Posted on Jun 25, 2009
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
Xerox Workcentre C2424.
You likely need modify darkness or the contrast.
Please take a look at the following from the Xerox site:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=458,E=0000000001668056207,K=4248,Sxi=0,Case=obj(6796)
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
Sep 19, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Xerox c2424 prints horizontal lines in all prints
Scroll the menu for troubleshooting, then run the Eliminate Light Stripes mode a couple of times
Apr 12, 2009 | Xerox C2424 Copier
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox c2424 Printer won't work
34 codes are related to the print head. Print head NVM or the print head itself. Most likely, I would say 95 percent chance of a print head failure.
Mar 01, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Scanner workcentre xerox C2424
Have you tried going to Xerox.com, click on support, then enter the 2424, then support again, then type in scanning? There is a lot of info there.
You can also call 1-800-821-2797 and ask for second level support.
Apr 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
291 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
