Question about Husqvarna Designer I
Programming When I touch the screen to program stitches - it doesn't respond to the letter touched it shows the one to the right of the one touched.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Hi
Sounds like a screen calibration problem. Will need a dealer to check it and recal if required.
Posted on Oct 22, 2007
Bernina 880 will not respond to touch screen
Recalibrate touch screeen:
Access is achieved by simultaneously pressing the needle position buttons < > and at the same time switching the machine on.
• Brightness is adjusted by turning the stitch length knob.
• Touch the cross symbols on the touch-screen for calibration.
Jan 01, 2017 | Bernina Sewing Machines
How do we fix a repeating touch screen on a Janome 5700. The touch seems to be ok., but the display is not.
You might try recalibrating the screen. Short of that, could be a computer screen component is failing.
Nov 13, 2016 | Janome Sewing Machines
How do i restore designer pape only letter page is showing on screen have husqvarna designer 1 with 4d embroidery extra
I'm not sure I understand the problem exactly. It sounds like you touch pad is not responding properly. Did you notice before this happened that you needed to touch the screen not exactly where the button on the screen comes up. If that is the issue your best bet is to have a husqvarna Viking tech and have the touch screen calibrated.
Feb 11, 2015 | Husqvarna Viking 1
My touch screen doesn&#39;t respond to touch what can I do?
techincally, you would have to take it to your nearest janome dealer and have them install a new touch screen...it might be something as simple as the digitizer which is the "touch" part of the screen which allows you to select your stitches ETC.
Sep 11, 2014 | Janome Memory Craft 10000
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
How can I program a full name into my 1+Husquvarna Sewing machine?
I have the #1 and it should be similar in programming if not the same.
Instructions for the #1 (1200) -- Programming Block Letters
(one model down from the #1+ Husqvarna)
From the machine instruction page for letters and numbers
Ready:
  • .Fabric Woven-medium, stitch & tear
  • .Enter: Woven-medium on your sewing advisor
  • .Consult Info display: Presser Foot B
Program:
Insert Cassette B
  • .Touch SELECT function to PROG
  • .Advance to an empty memory
  • (->) means arrow: .Touch H-> U-> S-> Q-> V-> A-> R-> N-> A (STOP) -> REP
Sew:
  • .Place Stitch & Tear against the wrong side of your fabric.
  • .Stitch the word HUSQVARNA. Easy!
  • .Now, program your name and today's date. Stitch on your sample.
Smaller sizes of letters
You can program a number of letter sizes by - the width before entering the letter. You may want to enter the first letter of a name at 6.0 width and the other letters narrower.
Correcting Errors
You may clear any single stitch but the first one on a program. When the cursor is under the first stitch and you touch CLR, the entire program is erased.
NOTE: The cursor designates the first letter to be sewn.
Oct 15, 2011 | Husqvarna Viking 1
Touch screen unresponsive
Whats the model number and type? A designer with the large touch screen can lose its programming on the screen and needs recalibrating. Models can be different and some have codes that need to be entered. Respond to this with the info and I will look it up and reply.
Derek
Jan 21, 2011 | Husqvarna Sewing Machines
I have a designer 1 and when i select the option block that I want - i actually have to touch below it a whole block for it to register what I wanted!! Help!! We moved states away from where I bought it.
Do you mean that you can't select a stitch except by touching below that stitch instead of on it? If yes, then you need to re-calibrate your screen. It's easy! You should use your stylus for this, but if you have lost it use the blunt end of a machine needle instead.
Go into your SET menu, hit More twice - or until you see "Color Touch Screen Adjust" (it might depend on what version machine software you have loaded just which screen it is on). Click on this. (Keep touching below and around the button until you get it to respond.) Touch in the CENTER of cross 1 (upper left corner of screen). When the cross changes from black to green, the point is set. Do the same with cross 2 (lower right). Done!
Just be sure to touch ONLY THE CROSSES on that screen, except for OK when you are done.
Nov 29, 2009 | Husqvarna Designer I
Touch screen not responding
Hi, my dealer told me mine might be going and it would cost $500 to repair it and it would have to be sent back to Janome for the repair.
He said when it goes, it will be stuck on the last stitch you used.  You can still probably keep it for a straight stitch machine if you did not want to send it for repair.
Jan 06, 2008 | Janome Memory Craft 9000 Computerized...
Touch screen not responsive
You need to re-align the touch screen using the following routine:
Accessing Alignment Mode:
Then you will see a text message something like
"Press + to align"
STOP
Don't touch the "+" in the text message !!!!!
The one you want will be elsewhere on the screen and all on it's own, with no text around it.
Using the non pointed end of a needle, or the spare spool pin (nothing sharp) gently but as accurately as you can, touch the centre of the +
The + will move to several more locations as it organises the height, width and orientation you give by touching the centre of the + as it appears each time.
When it is finished, turn machine off, then on as normal.
If this does not correct the issue, it may well be something else, so please, if you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Sewing Machines Logo
137 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
