Question about Toshiba Tecra M2-S530 Notebook
Will not boot up
I have a Toshiba Tecra M2 that will not boot up. I could get it to boot a few extra times by removing the main memory chip under the keyboard and reinstalling. This is no longer working. Plug it in-AC power and battery LED light in front. Power light comes on the front when you push the power button.Push and hold the power button again, and power light goes out. This is all it does, no display, no fan, not HD start up. After awhile the AC power LED goes from straight green, to blinking amber. Tried removing the battery and trying to boot-no help. Tried different processor-no help. Tried different RAM chip-no help. Tried external monitor-nothing. Tried different power supply-no help. Leaning toward motherboard, and if so, looking for advice as to where on the motherboard. Thanks
  • 1 more comment
  • mrgr8ness May 27, 2009
    I got it used. I would guess 4-5 years old. The cpu does not spin.
    Thanks
    Thanks for the replies. I will check out the connector. The laptop is completely disassembled right now. Had it apart and back together a few times, hoping for a bad connection fix.
    Frank, can you tell me more on checking the voltages? Is there a diagrahm available, where to take the measurements?
    Thanks
  • Frank Zhang
    Frank Zhang May 11, 2010
    how old the laptop? can you see cpu fan spin a while when power on?
    Scholar:
  • 92 Answers
I have seen a lot of Toshiba Laptops with bad "DC Connectors" on the motherboard. It sounds like you know what your doing so here a link on how to disassemble your laptop.http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
and here is another on how to repair the dc connector. http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
Posted on May 27, 2009
  • 191 Answers
This is motherboard hardware issue
1) first all you need take out all devices like HDD DVD, wireless card then try turn it on if noting yet
2) change RAM stick that you have done
3) check DC PWM standby status, like 3V/5V/1.8V which should be appear before power on.
if no 3V/5V DC output, check this PWM circuite like MOSFET or PWM chip.
if you find 3V/5V, so need check 1.8V DC output and 1.2V that chip fail also cause nothing turn on.
all steps need diagram check where the chips and componenets on your board.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
  • Frank Zhang
    Frank Zhang May 27, 2009
    check step by step
    1) check any disconnection:
    ---DC jack socket pin to motherboard, the pins needs to be resoldered
    ---check DC insolated circuite (MOSFET) pins or resolder it
    2) check 3V/5V any shortage:
    --- check capacitor near the bigger magnet component there are two for 3V and 5V), use meter(set to OHM) to probe the OHM never lower than 500OHM, if lower to two digital number OHM that shortage occured need to take a deeply check
    if I find the diagram that similar yous. will show you a part of them:
    later. please take a rating thanks!
  • Frank Zhang
    Frank Zhang May 30, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
TECRA M2-S730 wont boot from cd or harddrive what is wrong?
The coin cell battery on the motherboard will stop it from booting if it's dead because the time and date is missing.
Sep 23, 2014 | Toshiba Tecra M2-S730 Notebook
Is it possible to run windows 7 on a Tecra M2-S630?
yea you can run windows 7 but you will need to delet your old windows under f2 or f12 what ever your lap tops boot setting is.
Feb 27, 2011 | Toshiba Tecra M2-S630 Notebook
Upgrading memory on Tecra M2
the other memory chip is under the keyboard.
Oct 20, 2009 | Toshiba Tecra M2-S630 Notebook
Toshiba Tecra M2 Video and Fan Problems
i think your charger have some problem, check it.
Jun 30, 2009 | Toshiba Tecra M2-S530 Notebook
Drivers for TOSHIBA tecra m2 ptm20u
Hi!
You can donwload free drivers from the following link---
Drivers for TOSHIBA Tecra m2 ptm20u
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Toshiba Tecra M2-S730 Notebook
I have a Toshiba Tecra M2 Laptop. I just installed (2) 1gb ram chips. Bios only shows 1.256 Windows only shows 1.256 Where or how do I access or show 2gb RAM>
This could be bad memory or possibly (but unlikely) a bad memory controller. To test this remove one stick and power it on and look at the size, than switch the pieces of memory and check that one. If they both show 1gb then try each stick in the other slot. If they both do not show 1 gb then there is the problem.
Jan 15, 2009 | Toshiba Tecra M2-S730 Notebook
Driver required NETWORK CONTROLLER for Toshiba tecra m2
i can not find the wireless lan driver for tecra m2
Oct 05, 2008 | Toshiba Tecra M2-S730 Notebook
Toshiba Tecra 8100 PIII laptop not booting
It could be a hard ware isuse. Try this.
If you have extra memory or removable Ram ( usually located on the bottom under a panel) Try removing it and starting it, with the ram removed. Then try putting it back in and starting it. If it works, it may be bad memory or it just needed to be reseated. Do this also with the cd drive and wireless card if it is removeable.
also try this with the battery, plug it in and remove the battery and see if it starts.
alot of laptops, like computers will not boot if there is a hardware issue.
The Beeping is a code. The number of beeps and how it beeps usually indicates an issue.
you could look the beep codes up on the toshiba website is the support center.
Good luck.
Apr 15, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Toshiba Tecra M2 Bios Lockout
Email me at : fixya-expert@live.com and i will help you to remove that bios password....
Beni
Feb 28, 2008 | Toshiba Tecra M2 Notebook
Toshiba Tecra M2-S530 Notebook Logo
409 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
