Question about General Electric Microwave Oven
Blows the powerstrip
I have a GE microwave oven that suddenly began to trip the powerstrip. It started after I ran it for about 20 minutes. It fried the powerstrip and the GE cord was hot to the touch. Anyway, I got a new powerstrip but the microwave trips that one, too; but didn't fry it yet. We've avoided using the microwave for more than a minute at a time, but it's frustrating because I rely on it. Anyway, do you have a clue about whether it's a problem with the wiring in the house or whether there's something wrong with the microwave? It's about 5 years old. The house is 60 years old! I don't mind buying a new microwave to be safe, but I don't want to throw it out if that's not the problem. Thanks for any advice.
  • 1 more comment
  • miri62026 May 27, 2009
    I use the powerstrip FOR safety. I didn't know that it's a fire hazard. How so?
    It the microwave trips the powerstrip, then won't it will fry the electrical outlet, too, if there's something wrong with it? This is an old house and doesn't have grounded outlets, although there's an updated circuit breaker board in the basement.
    I've always used a powerstrip with this microwave. It began to blow the strip only recently. The only thing different is that I have a small tv and electronic antenna attached to the same power strip. Do they use enough power to cause this problem, even though the tv's not on?
    Thanks. But I'm confused as to why this happens now, after the one time that I used the microwave for 20 minutes straight, without the TV on.
    Do you think the microwave is okay and it's simply a matter of overloading that circuit,
    or do you think there's a short in it and I ought to replace it with a lower-power model?
    It's GE model JES1656, but I can't find anywhere that says the wattage, and I don't remember what it is.
    This is the third power strip I tried. The last one is a heavy duty, metal brand with a surge protector. Would they all be bad or is the microwave just pulling too much power, meaning maybe there's a short or something else that suddenly went wrong? Thanks for your help. As you can see, I don't know much about electricity or electronics. I just want to be safe and not have to buy a new microwave unless it's necessary.
  • 10,865 Answers
Hello. I can help you. Let me review some info. about microwaves.
First of all, a microwave requires a lot of power. Most microwaves must have their own circuit to work well for a long time. Do not use any powerstrip or other extension cord, always plug a microwave directly into the wall.
The problems you are having are most likely due to your powerstrip than to your home wiring.
Plug your microwave directly into the wall and use it. If it works then discard the powerstrip as it is a fire hazard. get back and let me know how u make out.
Posted on May 27, 2009
  • 1 more comment
  • Joe Hogan May 27, 2009
    Actually any firefighter will tell you that ANY extension cord, powerstrip or not is a fire hazard. You have not indicated how many watts your microwave is but lets say it is 1200 watts, the most common size. 1200 watts is equal to 12 amps. Chances are the circuits in your house are 15 amps. What this all means is that the microwave alone is using about 80% of the power available in that circuit which is about the most use you want to put on a circuit.
    You have other things plugged in to the power strip, all of which draw watts, and amps. Not as much when turned off of course as when in use. A power strip might cost five dollars and a circuit breaker might cost 25 dollars. They both have a circuit breaker function. Soooooooo when you use the power strip, you are using a cheap little circuit breaker that will only take a little wear and tear.
    Back to your question. If you are using the TV and the antenna and the microwave all at once you are pushing the limit of power available thru the powerstrip and it will most likely kick on you.
    I think your microwave is fine and that your power strip is bad
    Hello again. Have you tried plugging your microwave directly into the wall outlet? If it works when plugged in directly then the microwave is fine and the problem is your power strip or the combination of items you have plugged into the power strip.
    if the microwave doesn't work when plugged directly into the wall outlet then the problem is your microwave.
    You should determine the wattage draw of your microwave. If it is 1000 watts, then the draw is 10 amps. In otherwords, divide wattage by 100 to get amperage.
    Next determine the amperage of your power strip. Genereally, it will be some where on the power strip, usually on the bottom.
    If your microwave is lets say 15 amps and your powerstrip is 12 amps the result will be the problems you have been experiencing.
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL DISPLAYS ARE ALL BLACK, CIRCUIT BREAKER NOT TRIPPED. The oven was actually working, then suddenly in the middle of warming the food, it did quit -...
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Nov 09, 2009 | GE JVM1190 Microwave Oven
All of a sudden my JE1540WW 003 has died.
check the slo blow fuse and the high voltage capacitor and the high voltage fuse. good luck.
Jul 10, 2009 | GE JE1540 Microwave Oven
Dead microwave
There are replacable fuses inside. Taking the microwave apart requires removal of a lot of screws and the cover that can be rather bulky. make sure it's unplugged and safe before you begin. you can get replacement fuses at radio shack, ect. be sure to buy the same type and amperage. if the blow a second time there may be other issues.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave power shut off and stopped working
You can test safety thermostats with an ohmmeter. There should be a short circuit between the device's two terminals if it's closed. (This doesn't necessarily mean the device is good, though. It might be opening at too low a temperature when the oven is operating.) A high resistance or an open circuit means the thermostat has opened and needs to be replaced. An appliance parts store should have suitable replacements, or you can order from a number of online vendors. I usually start at the Sears parts site. They have part information for many models, and usually pretty fair prices for parts. But once you have the part number you need, a Google search will let you shop around.
It does sound like your oven shut down because of a thermostat. One is normally mounted on the magnetron tube that supplies the microwaves, and another is on the cooking cavity. I've had to replace these many times. If the main power fuse blows the oven will not come back on until it's replaced. But you might also have bad solder connections causing the trouble as well. I've seen solder joints on the control board and power filter board cause dead ovens.
If you're not absolutely sure of what you're doing working on a microwave, you might want to let a professional check it over and make an estimate. There are potentially lethal voltages present, and microwave leakage may be a concern as well.
MAYTAGE MICROWAVE MMV5100AAB-SWITCHING BREAKER WHEN STARTING
is there a way to over ride the main board start button so i will know if the board is bad. or away to test this?.
Oct 29, 2008 | Maytag MMV5207A Microwave Oven
Model JVM 1650sho1
is there a fix for this problem mine does the same thing, i changed the powerstrip and it worked fine for a month, now it's doing it again runs for too minues or so then it trips the circuit breaker in the power strip
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Tripping of circuit breaker
Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
Nov 03, 2007 | GE JVM1440 Microwave Oven
General Electric Microwave Oven Logo
840 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
