Question about Kitchen Ranges
I have the same problem.  How do you access the panel? The model number is JGP945SEKSS
  • 105 Answers
Hi leslieulak..i have here a link for GE that you can check. pls. let me know if it will help. good luck!!!
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-80587.pdf
Posted on May 27, 2009
Remote control for a Philips LCD tv model #42PFL7422D/37
Check whether the remote sensor inside your TV is faulty. Repalce it. The part can be located just behind the infra-red window. You have to open the TV, unscrew out the front panel circuit board, to access and replace it. The part will look some what like these.
Jul 30, 2012 | Televison & Video
Toshiba 46 inch flat screen model number 46rv53ou
Click here to download the user manual to your tV. Go to page which displays its specifications. You will get all details there.
Apr 18, 2012 | Toshiba Televison & Video
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
I Have an insignia tv and lost the remote control, I was able to find a similar insignia remote control to the one I lost. How can I program the new insignia control remote I acquired to my insignia tv.
Hello
All Insignia TV remotes are not alike. The frequency of infrared rays out from each remote control will be entirely different to each other according tho the model numbers of the TVs and remote controls. A typical model will have same model number of remotes, and the remote you have got is with the same model of your tVs it must work proper. Otherwise you have to buy a new one for your Insignia TV model. you can bought from the authorised service center for Insignia at your town. If you have no access to authoised service center nearby you, just buy one universal remote control, which has set up codes for Insignia. . Check its manual, that it have setup codes for Insignia. OK.
Feb 05, 2012 | Insignia Televison & Video
Replacing a door switch on a whirlpool microwave
On most over the range models (you didn't mention your model number) you can access the door switches for testing after removing the grille and control panel assembly.
It would likely be the primary door switch, but that varies by model.
Also, on some models, this is caused by a blown TCO / thermal cutout / thermostat on the magnetron.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 16, 2011 | Whirlpool WMH1163XVS Microwave Oven
NO HEAT NO FLAME
This means you are getting no flame. Probably the most likely problem is the glow plug. All gas dryers use a glow plug ignition system. This plug is very fragile as well. You can call whirlpool directly with your complete model number and order the part or find it online using google or go to your local appliance parts store. In upstate new york, we have a store called Jacoby Appliance Parts. You will then take the lower access panel off the front of the dryer. There is 2 screws, I believe they are 1/4" nut driver screws. Once behind the front panel you will see the the whole glow plug assembly is held in place with 2 more screws, unplug the wire harness to the glow plug and remove the 2 screws. Be careful to hold onto the assembly as removing the last screw so it does not fall. Replace the glow plug being very careful to keep your fingers off the carbon glow plug area and very careful to not hit it against anything when returning the assembly to it's place in the dryer. Put all screws back in and front access panel back in place AND..... HAPPY DRYING!!!!!
Nov 03, 2011 | Dryers
I have a Rheem model 71-308. It only has a lower access panel. How do I access the upper heating element?
If your heater only has one access panel, then it only has one element. These are mostly in the 30 gal. electric models.
Oct 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Where is the defrost timer in a kitchen aid sde by side refrigerator?
a model number would help but here are two places to look, under the front at the botom or behind the light cover in the fridge, if not see if it has a small access panel on the back wall of the fridge about 3/4 of the way down...
Aug 21, 2011 | Kenmore Side by Side Refrigerator
WHERE IS THE FILTER PUMP AND HOW DO I CLEAN IT PLEASE
Hi and welcome to FixYa, I am Kelly.
Since I have to guess the make and model number I have to assume this is a front loading washer of some brand and make. This is a from the hip guess. Having said that and without a MAKE & MODEL number here is my GENERIC response that may or may not apply to your washer:
Most front loading washing machines have a panel in the lower part of the machine you open to expose the approximately 5 inches across circular filter head. You grasp the tab and rotate it 90 Deg CCW then pull it free of the machine. It will leak water so have something to catch the water with. If you have a make and model number I can probably find you a manual with pictures of your particular machine and how to access the filter.
Thanks for choosing FixYa,
Kelly
Jun 21, 2011 | Whirlpool Washing Machines
I have error code ER dH. Unplug and then replug
Error Code - erdh
Kenmore and LG 795 Series. Model 795.77556600 but most models use the same repair. Controller Part # 6615JB2005H
To Verify correct part. Check part number for your model number at
www.searspartsdirect.com
Don't be intimidated by this repair... The 'erdh' error code indicates - error defrost heater. Replacing the controller is EASY. The difficult part is removing everything in the freezer section to access the evaporator coil but hang in there and stay with it. You will not hurt anything if you use common sense.
The new part (defrost controller) is relatively inexpensive ranging $10 - $14. Here in the SouthWest I used Appliance Parts Depot for a $10 part cost. Don't forget to have 3-4 small wire ties to secure the defrost heater, defrost sensor and wires.
It would help to write down a few notes of some of the particulars during disassembly.
I had the same ERDH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel.
(See Diagram Image) I accessed it by removing the freezer door, all components inside the freezer, including the slide rails / tracks mounted on the sides of the freezer. Be careful when removing the rear white panel because an evaporator fan is mounted on the back of it and plugs into the back left side of the freezer compartment. You just saved yourself about $375 or more.
Stay With It & Good Luck!
Feb 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
