Question about Frigidaire Dishwashers
Display shows PF
Frigidaire Dishwasher Model# FDBB4365FC0
Display has PF blinking.
Air Dry and High Temp Wash LEDs are blinking
Electronic board has recently been exchanged.
    New Friend:
  • 56 Answers
This is an indication that the power to the unit has been interrupted (Power Failure)
Posted on Mar 03, 2010
The start button light is blue, on the screen is beeping the key. i can't use any of program. it shows one minute till the end of drying. what to do?
The exact definition of this error when the clean light is blinking means that your dishwasher is failing to heat the water in an allotted time. This problem can occur on Whirlpool, Kenmore, Kitchen Aid, Jenn-Air, and Maytag dishwashers. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times
Apr 16, 2016 | Dishwashers
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Apr 03, 2014 | Kenmore Dishwashers
The hi temp wash and air dry lights are blinking on my firgidaire dishwasher
Hi Dan, this is AP!
I understand you are experiencing some trouble with the lights on your Frigidaire dishwasher. On your particular model, FFBD1821MW, if there has been a power failure, then the "Hi-Temp Wash" and "Heat Dry" LEDs will flash. In order to stop the LED lights from flashing press Start/Cancel. This process should relieve your concern regarding the LED lights flashing. I hope this information proves helpful to some degree.
Best of luck,
Mar 25, 2014 | Frigidaire Dishwashers
PF, high temp wash and air dry lights blinking. Reset main breaker but no help.
Hello babe_dog01 - PF typically appears in window when dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad or resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Since you have already done so and it was ineffective contact a professional to move forward accurately. Dishwasher could possibly be experiencing a communication error, wiring failure or faulty control board.
Jan 05, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Two blinking lights on top
lights on my asko dishwasher start blinking into the cycle
Nov 18, 2008 | Dishwashers
Will not run
than either replace heater sensor or element.
Give me model number pls
May 03, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
667 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
