Question about Hotpoint Top Freezer 18.2 Cubic Foot Total Capacity Refrigerator
Hotpoint CTX21EASRRWH Freezer works/Refrigerator does not
Refrigerator/Freezer is 15 years old. The freezer is working but the refrigerator started losing its cooling capabilities over several weeks (so it seems). The refrigeraotr is now not producing any cold air that I can determine. The refrigerator is located in the garage and has worked flawlessly until now.
    Novelist:
  • 130 Answers
The refrigerator is not cooling that depends on freezer section also.if a problem is in freezer then also refrigerator stops working.in that case freezer works but refrigerator stops cooling. ------------ Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
this will help you. you can get parts at .www.repairclinic.com please do rate the solution.thank you for using fixya.keep updated.thanks
Posted on May 27, 2009
Suddenly the freezer in my refrigerator stopped working. The refrigerator seems to be fine. I don't know how old it is but about 10-15 years old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 04, 2011 | Magic Chef Refrigerators
I have a fridge/freezer about 15 years old. Have just noticed that the fridge is showing a temp of 22oC what do you think is wrong with it. I have never had anything go wrong with it before.
heatman101
Mar 19, 2011 | Hotpoint Refrigerators
We have a hotpoint refridgerater that has stopped cooling ..even the freezer and its only 2 years old....are their fuses they may have blown or maybe a reset button?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 11, 2011 | Hotpoint Refrigerators
Hotpoint fridge freezer ffa60 frost free bottom freezer has stopped working top fridge is ok 6 years old help!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 30, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 06, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Freezer has bad smell, cleaned entire fridge and freezer out, no help. working fine but smells ?? side by side model about 5 years old, maytag
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website. on  www.repairclinic.com
Mar 31, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Hotpoint Top Freezer 18.2 Cubic Foot Total Capacity Refrigerator Logo
100 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
