Question about Motorola Radio Communications
Pairing s9 headphones w/krzr
I cannot pair my headphones with my krzr phone. when i hold theon/off button down i cannot get the blue light to blink three times and turn and "hold"blue.
  • Oramous Jun 18, 2008
    Having the same problem. When i hold down the on button it does flash blue three times quickly but then despite not being connected to any other phones or devices it carries on flashing and wont got steadily blue hense not entering pairing mode.
OK I managed to get my head set to work. Make sure the unit is charged, press and hold both the 'ON' button (on neck piece) and the "PLAY/PAUSE' button on the right earpiece. Keep holding then the LED should flash Blue three times THEN flash alternate RED and BLUE. You should then be able to Pair the Device. Good luck
Posted on Jun 19, 2009
  • a_brooker Jun 19, 2009
    Scrub that, since posting the S9 has decided to not to pair again. Worked twice and now refuses to pair. Back to the drawing board.
  • a_brooker Jun 20, 2009
    Back again - I finally sorted it! Instructions as with my initial post but use the 'TELEPHONE' button on left earpiece (Centre Button)!!! Note to self: makes sure you know what you're talking about before posting!
I have a pair of Auvio colored Bluetooth headphones and i am unable to use them via bluetooth and reseting doesn't work and i cant find the headphones on bluetooth.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
Apr 29, 2017 | The Audio Players & Recorders
How do i pair my hs-bt102-bk to my lg p705g
First make sure that the phone and the headset are fully charged. Turn on the P705F and enable Bluetooth for the phone. Touch the Apps button and look for the Apps tab. Go to Settings and then find the Wireless and Networks section. Set Bluetooth to On. With the headset off, press and hold the answer button (on the back) for 7+ seconds and the red and blue lights blink alternately. Set your phone to look for available Bluetooth devices by tapping the Bluetooth menu. If needed, click on Search for devices. Find the headphones in the list. Type in the code 0000. If the blue light blinks 3 times and then once every 7seconds, it's paired correctly. If that fails, try again from pressing the Answer button.
I hope this helps.
May 12, 2014 | Radio Communications
The blue light does not blink,it is a steady light that will not turn off and it wont pair up with my phone
The only way to reset your headphones is by charging them and pressing the call button and volume up and it will work like new.
Mar 26, 2014 | AUVIO Bluetooth Headphones
Nuvelli NUV2882 Stereo Bluetooth Headphone User Manual
There's no manual available, but if you want to pair your headphones with a computer or a phone follow this steps:
1.- Fully charge headphones (leds turn from red to steady blue
2.- Press for 8 seconds the lower button on the right (it has a phone symbol)
pressing the "phone" button will turn on the headphones, but if you keep pressing it will force the device to go to " Pair mode" you call tell is ready by noticing the LEDs turning blue and red. onces pairing is successful you will see a steady blue LED.
Apr 04, 2012 | Radio Communications
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
My motorola h700 wont pair to my htc hero.when i hold the button down on the bluetooth, it lights up blue for 5 seconds then the light goes out
go into settings, look for wireless controls or bluetooth, should ask you to pair with the name of your bluetooth if it wont, turn off the bluetooth in the phone and turn off the bluetooth itself by holding down the button for about 6 secs till the light blinks a few times then goes out. turn the bluetooth function on on the phone FIRST, wait till it says its on, then turn on the bluetooth itself by holding the button down until the light blinks a few times then you get a solid light, it wont stay solid, it will blink a few times then go out blinking from time to time. go back to your phone and find the bluetooth menu and it should ask you if you want to pair, hit yes or whatever option you have and it should start pairing and then connect or you may have to hit the connect option if you have one they dont all connect automatically sometimes so you have to go through all this when you charge the bluetooth or turn it off. good luck.
Dec 14, 2010 | Cell Phones
My connector is frozen on blinking red and blue. It will not connect with the head phones and go solid blue.
Have you tried doing the same with the headphones? If you hold the power button down on both the transmitter and heaphones (get them both flashing red and blue), they might pair.
Jul 15, 2010 | Logitech FreePulse Wireless Consumer...
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
May 15, 2009 | Insignia Bluetooth Wireless Headphones...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
New bluetooth earpiece, no instructions
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done.
Jan 05, 2008 | OEM Systems Bluetooth Headsets - Model...
Radio Communications Logo
753 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
