Question about RTO K Tool McPherson Strut Spring Compressor
Someone installed used struts in the vehicle i just bought and put the wrong parts in the strut towers
I need a picture of front strut assembly
I bought the tool and figured it out.I also went to the wreckers and got the origional parts.
Posted on May 28, 2009
Front strut replcement 2006 buick lacross
Jack up and support the vehicle on the sub frame. Remove the wheels. Unbolt the strut to knuckle bolts. Unbolt the strut mount from the strut tower (3 13mm head bolts) Remove the strut assembly.
It your replacing with "quick struts" reinstall and have the alignment done.
If your just replacing the strut you will need to bring the old strut assemblies to a shop to have the springs compressed. Once the springs are compressed the strut nut can be removed from the strut and the strut can be replaced.
DO NOT ATTEMPT TO REMOVE THE STRUT NUT FROM THE STRUT WITHOUT COMPRESSING THE SPRINGS. YOU WILL HURT YOURSELF.
Feb 20, 2015 | 2006 Buick LaCrosse
How do you replace front broken coil spring on 1998 ford windstar? do you have a diagram, pictures or video?
Strut and Spring Assembly Removal
  1. Raise the vehicle on a hoist.
  1. Remove the front wheel and tire assembly.
  1. ani_caut.gif CAUTION: To avoid damage to the 6mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten to final torque the front stabilizer bar link-to-front shock absorber nut.
    Remove the stabilizer bar link retaining nut and disconnect the link from the strut.
  1. ani_caut.gif CAUTION: Do not allow the halfshaft to move outboard. Over extension of the CV joint may result in the separation of internal parts, causing failure of the joint.
    Remove the strut assembly-to-steering knuckle pinch bolt. If required, slightly spread the steering knuckle to ease the removal of the strut. Pry down on the lower control arm and roll the strut base out of the knuckle. Do not pry on the halfshaft, as damage may result. Wire the steering knuckle up to prevent the halfshaft from moving outboard.
  1. Partially lower the vehicle.
  1. Support the strut assembly and remove the top three mount-to-strut tower nuts. Remove the strut assembly from the vehicle.
  1. ani_caut.gif CAUTION: The strut assembly is under spring tension. Attempting to disassemble the strut without properly compressing the spring can result in injury.
    Using a suitable spring compressing tool, slightly compress the strut spring to relieve initial tension. Loosen the upper rod nut. Continue to compress the spring until the tension is relieved. Remove the upper rod nut.
  1. Remove all upper mounting parts, coil spring, and coil spring isolators from the strut and save them for reassembly. Carefully note the position of each part during removal to ensure proper reassembly. Inspect each part for wear and damage as it is removed.
Installation
  1. ani_caut.gif CAUTION: The bearing and seal assembly is press-fit onto the upper mount. The mount washers must be installed in the correct orientation.
    NOTE: Be sure to check the spring insulator for damage before assembly. If the outer metal splash shield is bent or damaged, it must be carefully bent back, so it does not touch the locator on the bearing and seal assembly.
    NOTE: New gas struts are shipped with the rod in a locked down position. To extend the new strut, remove the external tie down and/or rotate the upper end of the rod, counterclockwise.
    Install the coil spring insulator, coil spring, and upper mounting parts to the new strut assembly. Make sure the spring is correctly seated in both spring seats.
Item Part Number Description 1 ? Dust Boot (Part of 18045) 2 N803826-S100 Front Shock Absorber Mounting Bracket Nut
(3 Req'd) 3 N803952-S100 Washer 4 N808625-S100 Front Shock Absorber Nut 5 18183 Front Shock Absorber Mounting Bracket 6 3B455 Front Suspension Bearing and Seal 7 5310 Front Coil Spring 8 5414 Front Spring Insulator 9 18045 Front Shock Absorber A ? Tighten to 35-40 Nm
(25-30 Lb-Ft) B ? Tighten to 55-63 Nm
(40-46 Lb-Ft)
  1. ani_caut.gif CAUTION: Do not over tighten the lock nut; damage to the lock nut or piston rod could result.
    Install new rod lock nut and tighten it to 55-63 Nm (40-46 lb-ft).
  1. Remove the spring compressing tool.
  1. Position the strut assembly into the vehicle. Install the three mount-to-strut tower nuts. Tighten the nuts to 35-40 Nm (25-30 lb-ft).
  1. Partially raise the hoist.
  1. Position the strut assembly to the steering knuckle. Install the pinch bolt and tighten it to 115-132 Nm (85-97 lb-ft).
  1. Position the stabilizer link to the strut assembly and install the retaining nut. Tighten the nut to 90-100 Nm (66-74 lb-ft).
  1. Install the front wheel and tire assembly.
  1. Lower the vehicle.
hope this helps
Aug 14, 2011 | 1998 Ford Windstar
Does this car have shocks front and rear??
Yes but they are called struts on the front and the shock are for the rear . Here is a picture..... Of the front.... mcneb_14.jpg>>>>>>>>>>>>>>>>>>>>..............................................................................................................................................................................................................................................................Here is a picture of the rear............................................................................................... mcneb_15.jpg
Feb 09, 2011 | 2000 Mercury Sable
Are struts on the front or back of this car?
The struts model (MacPherson Strut),are both in front and back of this car.
2000 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Rear, Driver Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly. $72
2000 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Rear, Passenger Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $68
1996 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Front, Driver Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $67
1996 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Front, Passenger Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $63
Of course this is only the cartridge, you have to transfer the spring, and the top mount of the existing strut. You need a pair of coil spring compressor to do the job. The basic procedure to replace a strut is:
Remove the top nuts that secure the strut assembly to the frame mount inside the engine compartment. Do not remove the center nut.
Mark the lower strut mounting location on the hub for installation reference. The alignment will be close if the new strut is installed in the same position.
Remove the bolts that hold the strut assembly to the hub.
Mark the top mount for installation reference. Using a side mounted spring compressor, compress the spring and remove the top nut and retaining washer. Pull strut assembly out from the bottom of spring.
Slide the new strut assembly up into the spring and reposition the top mount onto the spring in the same position that it was removed. Install the retaining washer and top nut.
Tighten the top nut to the manufacturer's specifications and carefully remove the spring compressor.
Place the strut assembly back into the vehicle.
Oct 16, 2010 | 2000 Hyundai Elantra
How to replace the shocks on my 2000 Mazda 626
REMOVE**** FRONT SHOCKS, FIRST OF ALL.SUPPORT THE LOWER CONTROL ARM WITH A JACK,REMOVE FRONT WHEEL, REMOVE BRAKE HOSE AND ABS SENSOR HARNESS TO THE STRUT BOLTS OR CLIPS,REMOVE ACTUATOR FROM TOP OF THE STRUT,IF EQUIPPED WITH AUTOMATIC ADJUSTING SUSPENSION. PAINT ALIGNMENT MARKS ON THE UPPER STRUT MOUNTING BLOCK AND STRUT TOWER AND ON THE LOWER STRUT MOUNT TO STEERING KNUCKLE SO THAT CAN BE REINSTALLED IN THE SAME POSITION. REMOVE UPPER STRUT MOUNTING NUTS, REMOVE THE STRUT TO KNUCKLE BOLTS,REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT INTO THE STRUT TOWER ALIGNING THE PAINT MARKS MADE DURING REMOVAL.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 34 - 46 FT LBS. INSTALL STRUT TO KNUCKLE BOLTS TIGHTEN TO 55 - 61 FT LBS. INSTALL ACTUATOR AND ENGAGE THE ELECTRICAL CONNECTOR IF EQUIPPED WITH AAS. INSTALL BRAKE HOSE AND ABS SENSOR HARNESS CLIPS OR BOLTS.INSTALL WHEEL AND CHECK ADJUST THE FRONT END ALIGNMENT. TO ( REPLACE REAR SHOCKS ) REMOVE REAR WHEELS, REMOVE REAR PACKAGE TRIM. REMOVE SPEED SENSOR HARNESS, REMOVE TOP STRUT NUTS,THE SUSPENSION WILL DROP WHEN THE WEIGHT LIFTS OFF THE WHEELS. REMOVE BOTTOM STRUT BOLTS.REMOVE STRUT ASSEMBLY.TO INSTALL ***** INSTALL STRUT ASSEMBLY, INSTALL BOTTOM STRUT MOUNT BOLTS AND TIGHTEN TO 55 - 61 FT LBS.INSTALL UPPER MOUNTING NUTS AND TIGHTEN TO 33 - 46 FT LBS. INSTALL SPEED SENSOR HARNESS.INSTALL REAR PACKAGE TRIM. INSTALL REAR WHEELS.
Sep 22, 2010 | Mazda 626 Cars & Trucks
How to change a front coil spring on a 2002 pontiac grand prix
A spring compressor is needed for this. This can be very dangerous to do . Best to leave it to the profesionals
Nov 08, 2009 | 2002 Pontiac Grand Prix
How do I change the rear shock on my 1999 Dodge Neon?
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Unfasten the retainer(s), then remove the hydraulic flex hose bracket from the strut bracket. If equipped with ABS, the wheel speed sensor cable routing clip is also attached to the strut assembly bracket.
  1. Support the rear knuckle, suspension and brake components before removing the clevis bracket-to-knuckle attaching bolts. Do NOT allow the weight of the knuckle and related components hang without support when the strut is removed.
  2. WARNING The knuckle-to-strut attaching bolts are serrated and must not be turned during removal. Remove the nuts while holding the bolts stationary in the knuckle.
  1. Hold the bolt with a wrench, then unfasten the 2 clevis bracket nuts attaching the strut to the knuckle.
Fig. Fig. 2: Location of the knuckle-to-clevis bracket bolts
  1. Carefully lower the vehicle, then open the trunk. Access to the rear upper strut mount-to-strut tower attaching bolts is through the trunk of the car.
  2. If necessary, remove the carpet from the top of the strut tower. Then, remove the rubber dust shield from the top of the strut tower for easier access to the upper strut nuts.
  1. Loosen, but do not remove the 4 upper strut mounting nuts. Then, while supporting the strut assembly, fully remove the 4 strut mount attaching nuts.
  1. Remove the strut assembly from the knuckle by sliding the knuckle out of the clevis bracket on the strut, then remove it from the vehicle.
Carefully pull the strut assembly out of the vehicle
To install:
  1. Position the strut back into the vehicle with the 4 studs on the strut mount assembly through holes in the strut tower of the vehicle. Install the 4 strut mount-to-body attaching nuts onto the mount studs. Tighten the nuts to 25 ft. lbs. (34 Nm).
  2. Install the dust shield into the opening on top of the strut tower. Install the carpeting back on top of the rear strut tower.
  3. Raise and safely support the vehicle.
  4. Install the knuckle into the clevis bracket on the strut assembly. Install the 2 clevis bracket-to-knuckle attaching bolts and nuts. Hold the bolts with a wrench while tightening the nuts to 70 ft. lbs. (95 Nm).
  5. Install the brake hose bracket to the strut bracket and secure with the retaining bolts. If equipped with ABS, the wheel speed sensor cable routing clip is also attached to the strut bracket.
  6. Install the wheel and tire assembly on the vehicle. Tighten the lug nuts evenly, in sequence, to 100 ft. lbs. (135 Nm).
  7. Carefully lower the vehicle.
  8. Have the toe checked and adjusted as necessary.
Nov 05, 2009 | 1999 Dodge Neon
Removed old strut last night Today can't get new
Installation
  1. sww~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The bearing and seal assembly is press-fit onto the upper mount. The mount washers must be installed in the correct orientation.
Item Part Number Description 1 — Dust Boot (Part of 18045) 2 N803826-S100 Front Shock Absorber Mounting Bracket Nut
(3 Req'd) 3 N803952-S100 Washer 4 N808625-S100 Front Shock Absorber Nut 5 18183 Front Shock Absorber Mounting Bracket 6 3B455 Front Suspension Bearing and Seal 7 5310 Front Coil Spring 8 5414 Front Spring Insulator 9 18045 Front Shock Absorber A — Tighten to 35-40 Nm
(25-30 Lb-Ft) B — Tighten to 55-63 Nm
(40-46 Lb-Ft)
  1. sww~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over tighten the lock nut; damage to the lock nut or piston rod could result.
May 01, 2009 | 1998 Ford Windstar
I need step by step instructions to replace front struts.
1.Turn ignition to OFF position to place steering column in unlocked position.
2.Remove hub nut
3.Loosen, but do not remove, three top mount-to-shock tower
4.Raise vehicle on a hoist.
5.Remove tire and wheel assembly
6.Move brake caliper and wire out of the way
7.Remove brake rotor
8.Remove cotter pin from tie rod end stud and remove slotted nut.
Discard cotter pin and nut
9.remove tie rod from knuckle
10.Remove stabilizer bar link nut, and remove link from strut
11.Remove and discard lower arm-to-steering knuckle pinch bolt and nut. (A drift punch may be used to remove bolt.) Using a screwdriver, slightly spread knuckle-to-lower arm pinch joint and remove lower arm from steering knuckle.
12.Press halfshaft from hub
13.Remove shock absorber strut-to-steering knuckle pinch bolt. Using a large screwdriver, slightly spread knuckle-to-strut pinch joint, if required, for removal
14.Remove steering knuckle and hub assembly from shock absorber strut
15.Remove three top mount-to-shock tower nuts and remove strut and spring assembly from vehicle
16.Compress spring with Spring Compressor
17.Place 10mm box-end wrench on top of shock strut shaft and hold while removing top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet
18.Loosen Spring Compressor , then remove top mount bracket assembly, bearing plate assembly and spring.
INSTALLATION
1.Place a 10mm box-end wrench on top of shock strut shaft and hold while tightening top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet to 53-72 Nm (40-53 lb-ft).
2.Install strut and spring assembly and three top mount-to-shock tower nuts
3.Install steering knuckle and hub assembly to shock absorber strut.
4.Install a new shock absorber strut-to-steering knuckle pinch bolt. Tighten to 98-132 Nm (73-97 lb-ft).
5.Install halfshaft into hub
6.Install lower arm to steering knuckle ensuring that ball stud groove is properly positioned and boot seal is not damaged. Install a new pinch bolt and nut. Tighten to 53-72 Nm (40-53 lb-ft).
7.Install stabilizer bar link to strut and install a new stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft).
8.Install tie rod end onto knuckle.
9.Install a new tie rod end slotted nut. Tighten to 31-47Nm (23-34 lb-ft).
10.Install a new slotted nut retaining cotter pin.
11.Install brake rotor
12.Install brake caliper
13.Install tire and wheel assembly
14.Tighten three top mount-to-shock tower nuts to 30-40Nm (23-29 lb-ft).
15.Lower vehicle and tighten hub nut to 230-275 Nm (170-202 lb-ft)
16.Depress brake pedal several times prior to moving vehicle.
Hope this helps. Good luck !
Mar 14, 2009 | 1992 Ford Taurus
Front struts replacement
Jack up and secure front end of your vehicle,Take off two front wheels. Loosen to bolt on the bottom of struts (Its a bolt and nut). Remove clip that holds brake hose on to strut and remove hose. DO NOT OPEN BRAKE LINE OR DISCONNECT FROM CALIPER. Remove bolts and remove bottom of strut from knuckle/Hub assembly. Then loosen nuts on strut tower( on top of fender inside hood) (3) nuts, mark exact locations of each nut on strut mount area on upper fender weld. Make sure to hold strut on the bottom so it doesn't drop down on caliper and knuckle or on you possibly.YOU WILL NEED A SPRING COMPRESSOR to compress spring so you can take struts off. MAKE SURE THAT SPRING IN COMPRESSED/SQUEEZED WITH A STRUT COMPRESSOR. Then loose center nut on strut tower(may be covered with a circular rubber cover) If nut spin around with out getting loose use vise grips to hold strut rod ONLY TO REMOVE STRUT NOT TO INSTALL. if you use vise grips to install it will damage strut. When nut is off, remove strut and reinstall new one transfer all rubber boots and cushions from old strut. Good Luck thanks for using FIX-YA.com contact me if you need more help.
Dec 30, 2008 | 2004 Nissan Altima
RTO K Tool McPherson Strut Spring Compressor Logo
236 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
