Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Not sucking up dirt off floor any longer
My Bissell Powerforce doesn't want to **** up dirt anymore. It leaves most dirt still on the floor. I've cleaned the fliter but it still doesn't work. Should I completely replace the flirter???? Thank you!
  • 10,865 Answers
Chances are there is some blockage in the pathway from the floor to the bagless colllector. Use a flash light to look in the tube and straighten out a wire coat hanger to probe the areas you can not see.
Finally if your vacuum has a beater bar/brush that spins against the floor check to see that it is spinning. If it is not, that indicates that the belt which drives the brush is broken.
good luck.
Posted on May 27, 2009
Bissell 3522 can use to wooden hard floor
Hi Marian. Thanks for asking this question. The Powerforce vacuum has a bare floor setting; however, you may want to contact the hard floor manufacturer for their recommendation regarding the use of a rotating brush.
Aug 12, 2013 | Bissell 3522 PowerForce Bagged Upright...
I have bissell powerforce turbo bagless upright vacuum. Its a great machine. It is clogged though. I think I was not emptying the dirt collection tray thing enough. How can I unclog it. Its not sucking up...
remove the hose , clear that , then if you take a wire hanger apart you can pull whatever is remaining out of that connection, also remember to clean ( if you have the cleanable filter) the filter and also the top one
May 18, 2011 | Bissell Vacuums
My Bissel powerforce 6596 has suction but the dirt is not making it into the dirt cup. If I shut it off, the dirt drops to the floor. Also the motor seems to be over heating. All filters are clean. I...
Just because you cant see the obstruction doesnt mean theres not one. The hose could be stopped up somewhere not visible to your eyes. I have one and I have to take hose off and apart to clean it out. check the roller. Is it rolling?
May 17, 2011 | Bissell 6594 PowerForce Bagless Upright...
It's blowing dirt out the bottom/back
this is caused by a plugged up suction hose AND / OR a dirty filter.
clean the filter - and remove the bottom floor plate and clean out the hose where it bends down to the floor unit ( this is always where the dirt collects when the filter gets dirty and suction is low ).
c...
Feb 22, 2011 | Bissell 6594 PowerForce Bagless Upright...
Sucks Well but Leaves a Trail of Dirt
It sounds like you have a clog and what you will need to do is start at on end and then work you way to the other. You might try a coathanger and straighten it out to so can work it to the areas that you can't reach.
Jan 17, 2010 | Bissell Vacuums
We have this vacuum and its not sucking enough. its sucking at about 50% capacity. we vacuumed an entire room and when we opened it up, there was nothing in the dirt holder. we have cleaned all filters and...
A common probem with vacuums that are equipped with an attachment switch is the switch isn't all the way in it's normal position. Our Bissell has a yellow dial that switches from normal to attachment mode and will only work at 1/2 its power if the switch isn't in vacuum mode.
Dec 13, 2009 | Bissell 6594 PowerForce Bagless Upright...
Dirt doesn't make it to cannister ...it used to have the spin around affect now it just sits there but some dirt is leaving floor....it is in the hose..I have cleaned ALL filters ...YUCK......help
You have a broken belt. Turn the vacuum over and remove cover plate. You will probably find a broken rubber belt. Buy a new belt for your vacuum. Remove the brush , install the new belt with the brush. Put cover plate back on. You are ready to go!
Jim
Jun 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Hello, I have the same model. And though it is three years old, starting from the last month, it does not clean anything anymore. Cannot even pick up one single thing from the floor. Every dirt gets stuck...
i know bissell vacuums are very cheap but they should last more than 3 years. there should be two parts to the dirt cup. remove the dirt cup and above it there should be a round plastic part. unscrew it and check that filter.
Apr 06, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell bagless
I had the same problem, called Bissell over 10 times! They send me 3 plastic inserts for the dirt chamber, not the problem. I solved it by throwing the Bissell away and buying a Eureka bagged vacuum, no more problems.
Oct 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
280 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
