Question about Toshiba TZ55V61 55" Rear Projection Television
Toshiba auto shut off
Toshiba TZ55V61 just keeps shutting itself off and the power light keeps blinking like it is in a standby mode. I can't turn the tv back on without unplugging the power cord. it started turning itself off about six months ago and it was very random, and about once every couple weeks. u would be watching tv for a couple hours and all the sudden it would turn off and u would have to reset it by unplugging. and over time it began doing it more frequently and after shorter use. by now it wont stay on for more than a minute and sometimes unplugging it and plugging it back it dosent even do the trick. sometimes it shuts down immediately after plugging it before it even powers up. if anybody could help it would be greatly appreciated. i dont have the money right now to replace and it has been a great tv and still has a great picture and i'd like to fix myself if possible. any advice?
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Sr576 standby light blinking
Most likely, you have DC Offset(a bad amplifier). The unit is shutting down to protect your speaker system, as well as protect the unit from any further damage. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jul 22, 2012 | Onkyo TX-SR576 7 Channels Receiver
When you turn it on it might go on then turn off or it might not go on at all the power light blinks won't shut off unless you unplug the TV.j
The blinking LED is the Fault code for your set. Its shutting itself down into protection mode to stop from further damaging itself. Kinda like a fail safety. My fix instruction differ for rear projection than that of PDP or LCD but its the same. Just a dif set up inside the set.
Aug 06, 2010 | Toshiba TP50H50 50" Rear Projection...
Hello, My PS3 just keeps turning itself off. I have tried to reset the system but it keeps flashing red and yellow lights and then turns itself off into standby mode? HELP......
Try removing the game inside your disc. then try removing other external hardware and slots and try again. If problem persists it might be a system problem. Please go to the shp from where you bought it and ask them for a replacement.
May 16, 2010 | Sony Playstation 3 (PS3) Console
The TV shut off by itself. Just before it went off, it said "timer off 0:00 press 09". Now when I push the power button the power light blinks and there is no picture.
sounds like somebody set the timer. normally this only makes the set enter standby mode and pressing the power button or a channel button usually wakes the set normally.
Just a longshot but have you tried pressing 09 while the light is blinking?
Mar 21, 2010 | Toshiba CZ32V51 32" TV
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
TV turns off by itself after being on for 60 seconds
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Hope this helps.
Jan 13, 2008 | Toshiba CN36X81 TV
Toshiba TZ55V61 55" Rear Projection Television Logo
290 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
