Question about Zebra Stripe S600 Thermal Label Printer
Hex Dump How can I do a hex dump on a Zebra S600 barcode label printer?
  • 13 Answers
Turn printer off. PRESS & HOLD PAUSE & FEED buttons after power goes out. While holding turn printer ON, count to 3 & let go. once printer does its checks press the MODE button 4 times to SAVE. the bottom 3 lights will flash 1 time. This should reset the entire printer including calibration, communications & everything to be like it just came out of the box.
Posted on Jun 03, 2009
How do I reset dcp-8045d hex dump mode
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Apr 02, 2015 | Brother DCP-8045D All-In-One Laser Printer
It states 'hex dump' on my printer and I don't know what it means
A hex dump is a list of hexadecimal numbers (base 16 numbers) of probably the contents of the memory.
This Hex dump is generated when the computer comes across a computer problem and can help Microsoft determine the cause and fix if this is sent to Microsoft.
Mar 13, 2011 | Office Equipment & Supplies
I am sending raw data to the printer. Where to find ESC codes for different control ops
This feature allows experienced users to see exactly what data is
coming to the printer. This can be useful in finding software
problems. When you turn on the hex dump function, the printer
prints all commands and other data in hexadecimal format, along
with a guide section to help you find specific commands.
To use the hex dump feature, follow these steps:
1. After you make sure the printer is off, open the cover.
2. Hold down the FEED button while you turn on the printer.
3. Close the cover.
4. Run any software program that sends data to the printer. The
printer prints “Hexadecimal Dump” and then all the codes it
receives in a two-column format. The first column contains the
hexadecimal codes and the second column gives the ASCII
characters that correspond to the codes.
Hexadecimal Dump
1B 21 00 1B 26 02 40 40 . ! . . & . @ @
1B 25 01 1B 63 34 00 1B . % . . c4 . .
41 42 43 44 45 46 47 48 ABCDEFGH
❏ A period (.) is printed for each code that has no ASCII
equivalent.
❏ During the hex dump all commands except DLE EOT and
DLE ENQ are disabled.
5. Open the cover to set the printer off line, so that it will print the
last line.
6. Close the cover and turn off the printer or reset it to turn off the
hex dump mode.
PLEASE CHECK THE LINK TO GET THE ESC CODES:
http://www.mit.edu/~vona/MSim/vona/terminal/VT100_Escape_Codes.html
Hope this helps u ..............
Feb 21, 2010 | Epson TM-T88III Thermal Printer
DCP 8045D Display says Hex Dump Load - What does this mean - How do I get rid of it
I resolved the " Hex Dump Mode" problem
Step1: switch off power
Step2: press and hold Stop/Exit ( Red Color Key ) switch on power supply .......
now no " Hex Dump Mode" problem
Jan 19, 2010 | Brother DCP-8040 Copier
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
Just tell me how to reset printer into factory settings. I have tried it by LPT1 connection and commands sent from command prompt, but doesn't help. The problem is that printer after print request...
To reset the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 28, 2009 | Zebra LP 2844 Thermal Printer
Tlp 2844 printing first page ok then prints another blank
First thing to try is a reset of the printer.
5) Push feed
David
Jan 03, 2009 | Zebra LP 2844 Thermal Printer
MY UPS PRINTER IS NOT RUNNING ZEBRA: UPSLP2844
Bit of a tough one to know where to start "Printer is not Running"
They usually sit on a bench and do not run anywhere :-)
Is your power supply plugged in?
Is there a green light on the power Supply?
Is the printer turned on?
Does the green feed button cause a label to eject?
If yes to all the above then try a reset
5) Push feed
David
Dec 09, 2008 | Zebra LP 2844 Thermal Printer
I have a brady label machine 2461
Hex dump mode is mostly used for trouble shooting of the printer. To exit the hex dump mode, enter the Diagnostics menu / Hex
Dump Mode and select ‘Disable’. Exit the menu, save changes and
return to the ‘READY’ mode.
Dec 07, 2008 | Brady 2461 Thermal Label Printer
TLP 2824 Sebra
is the printer an EPL or ZPL model? i will need to see a hex dump of what you are sending to the printer to pin point the error but it sounds like a label layout issue.
is the barcode content the same on each label? if the barcode content is changing the barcode will grow and move to the right.
Nov 07, 2007 | Zebra TLP 2824 Printer
Zebra Stripe S600 Thermal Label Printer Logo
466 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
