Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
My dryer Model # FDGC648GHSO was converted to run on propane using conversion kit #131776600 and I was wondering what has to be done to convert it back to natural gas.
  • mrbig440 May 27, 2009
    Thank-you for your reply the only parts they left me was fame control tube with a different dia. and ignitor is this all that is necessary? Thanks again for you help Mark
  • 10,865 Answers
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
Posted on May 27, 2009
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 | Grilling
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Crosley cdg6000w
Here is the propane conversion kit for that model. The kit comes with instructions.
Nov 24, 2012 | Crosley CDG6000 Gas Dryer
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
Convert Whirlpool dryer from propane to gas
You must purchase a conversion kit from your appliance parts store.
Mar 21, 2009 | Whirlpool ET8CHEXSQ Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Natural GAs to Propane
Call Maytag or whirlpool!
Whirlpool makes Maytag now same company
They make a conversion kit!
ngafm at your service.
Please rate me before you sign out!
Sep 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
864 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
