Question about Sub-Zero 661/F Side by Side Refrigerator
Won't stay cold...
15 years old SubZero side by side. Is it worth trying to fix? 1 repairman said compressor shot...thanks
  • sakietzman May 27, 2009
    He said he would try adding more freon does that make sense??
    THANK YOU SO MUCH!
    President:
  • 1,902 Answers
If the compressor is shot, then there is not any reason to keep it. The parts and labor will cost you as much as a new fridge and then at that is not guarnteed to work correctly after the job is finished, or how long it will last afterwards
Posted on May 27, 2009
  • Jeremy Reddick
    Jeremy Reddick May 27, 2009
    If the compressor is really shot like he says. He can add all the freon he wants and change you like crazy for the freon and the problem still will not be fixed. This almost sounds like the compressor is not shot and I would recommend having another company come out and let them disagnosis it since anyone who knows compressors knows that if the compressor shot adding freon will not do any good at all.
  • Jeremy Reddick
    You are welcome sorry for the bad news and good luck with this
Hello i have a problem sub zero just keeps tripping breaker at panel any ideas why
Posted on Sep 05, 2010
MAYTAG SIDE BY SIDE MSD2650KEU
Check to see if the compressor is running and hot. Post back your results.
Dec 05, 2012 | Maytag Refrigerators
Fridge and freezer not staying cold
You didn't give age, make or model of your fridge, but I have found on two, made in the last 15 years that the newer models have a solid state starter switch on the compressor, and they don't last like the older coil-magnetic starters. They are a fairly cheap fix at around $50.00. Ask your repairman to test the compressor with his universal starter/capacitor most carry with them. Keith L.
Mar 02, 2012 | Refrigerators
My Amana 26 cu ft side by side quit cooling entirely in the freezer and the refrigerator. Is it worth it to get a repairman or should we just get a new frig. This one is 6 years old
I suggest get help with repairman.6 year old is not very old.Refrigerators have life more then 8 to 10 years.The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Oct 24, 2011 | Amana 26 cu. ft. Side-By-Side...
Does not stay cold. Even with
Sounds like the compressor, or a refrigerant leak. Being a year old I would call Frigidaire and try to get it fixed or replaced under warranty.
Jan 03, 2010 | Frigidaire FRT21H8 Top Freezer...
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refridgerator side of my side by side subzero is not cod enough. the coils are clean..what do I do now? the freezer portion is cold but is producing ice at a very very slow rate. the refridgerator is...
You probably have a leak in the evaporator and there is not enough refrigerant left to cool properly. Sub Zero has a 12 year warranty so You may want to replace the unit. You need to call a servicer to check it out.
Sep 22, 2009 | Refrigerators
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
SubZero fridge problems
Ice buildup on the back left wall is the sign of an evaporator leak. Not something you can fix yourself, at some point it is going to be completely out of gas, I would call for service now
Apr 07, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Freezer Compressor Leaks Oil and Stopped Working
Hi I'm a subzero asc (Autorized service center) Subzero would not be responsible, your unit is out of there warranty. Now if the service company your dealing with is any good they can get a new compressor under a part warranty from there part distributor. Also in my many years working on subzero I have never seen oil dripping from the compressor unless you have a leak somewhere in the sealed system. Unfortunately the only thing you can do is see if your service provider will fix the unit. they will charge you labor if they get the part in warranty. It's possible that the service provider did not to the job properly but that's your word against there's. Good luck I hope everything works out for you..
dmparenti
Jan 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Both sides are warm
can yiou tell me what the repairman did? the ticking is the air damper but the cooling is a separate issue. call a different repairman to have them take a look at the compressor, heat exchanger or evaporator as these could all the be source of the problem.
Aug 09, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Sub-Zero 661/F Side by Side Refrigerator Logo
468 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
