Question about Sony Audio Players & Recorders
Sony TC-255 reel to reel Tape won't turn
Belt is intact. Drive wheel and fan turn in neutral but stop when put in forward or reverse.
  • jenkins5790 May 11, 2010
    Do you know of a repairman in Atlanta, Ga with Sony TC255 reel to reel's.
You need to have a tape in place on the reals or it will stop.Hold the tape feeler spring in place and prevent it from moving forward it is located on the left side just remove the SONY stereo tapecoder cover and you see it
Posted on Dec 11, 2009
  • Electric Dime
    Electric Dime Jun 29, 2011
    These reel to reels have a common motor run capacitor problem. They often go bad, Located inside the machine next to the motor it looks like a small silver metal can with wires.
    CAUTION: If you are not familiar with working on electronic and how to discharge the electric current within the machine then do not try to service this yourself. If could be fatal.
    If the unit does not start when the tape is treadled correctly , goes for awhile and the slowly stops while in play, this is probably your solution above. It will need to be serviced by a qualified technician..
Is there an internal speed adjustment to fix tape speed selector that has no affect on tape speed. This is on Sony TC-440 reel to reel.
There is a cam with solidified grease on a lot of Sony Mechanisms. The deck need to be cleaned of the grease they used that solidifies and then a better grease such as Lubriplate 105 should be applied.
The Idlers need to be reconditioned as well. The Sony units can be labor intensive due to this required work but I do fix them when people want them done. I am in the Chicago area as Skywave Tape Deck Repair
Jun 08, 2015 | Audio Players & Recorders
How do i stop my vcr from destroying tapes?
What is probably happening is the take up reel is slipping or it could be a belt that moves the feed reel in reverse when you eject the tape. You might want to first put the VCR into rewind and see if it takes up the tape. If not then the belt is most probably the problem, or the rubber on the take up reel has glazed over and it is slipping.
I have fixed many of these and most all of the time it is that wheel or a bad or streached or glazed belt.
Good luck,
Marty
Jul 19, 2014 | Toshiba Televison & Video
Auto reverse
You do not list brand and model but it is typical that the belt replacement is missing the mark in that the reel rotation sensor is not detecting rotation of the reel table and therefore trying to go the other way. The reels have to be turning in play mode. If they do not auto stop or the reverse function thinks the tape is at end.
Apr 15, 2014 | Audio Players & Recorders
Where do i buy drive belt FOR SONY CASSETTE DECK TC-K8B
Any spares shop can make a match but otherwise this is for the round or square belts only You can fit a round belt in place of the square type it does not matter. I had some reel to reel machines and in desperation I went to a Hydraulic cylinder and pump spares shop and got an "o" ring of the correct length and thickness Remember that the new belt must be SLIGHTLY shorter to give grip on the pulleys. I have several units cassette and open reel that I was forced to fit this type and some some are running now over ten years everyday
May 02, 2013 | Audio Players & Recorders
I have a Teac A-6300 that won't go fast forward or reverse but the capstan motor is running
The Capstan motor is just for the play speed regulation so it has nothing to do with the reel motors. You can have an open safety microswitch or maybe a bad relay. It is really hard to say without looking at the unit but I am sure it is repairable. Is the right dummy plug put in the back? This can stop all transport functions if it is out.
Apr 14, 2012 | Teac Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Oct 15, 2010 | Sony Audio Players & Recorders
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC 530 tape speed problem
If it's slightly faster than normal, that's fine. You'll just need to check the rollers and tighten them slightly as well. They might be loose or sort of that.
Dec 26, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Cassette player problem
Sounds like the take-up reel isn't turning. Often the linkage for the take-up reel is used for both Play and Fast Forward. So test the Fast Forward.
I would look for a broken belt or slipping drive wheel. The fact that the tapes are unraveling tells me that the capstan is pulling the tape out of the feed reel.
Feb 09, 2008 | Audio Players & Recorders
794 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
