Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Workcentre C2424 System Error
Hi. I have a WorkCentre C2424 and after a long day of rains and lighting it started acting funny. The printer is giving a system error 07,007.40:77713. I have turned it off several times, I disconnected all cables and plug them again, and the Printer is still not printing or doing anything. Can anyone tell me what that error means and how to fix it? I call Xerox and they are charging me $332.00 for 30 mins of service.
    President:
  • 2,072 Answers
That sounds like a problem with what is called the process drive motor. It is the assembly that moves the maintenance kit up and down to clean the drum.
It is located on the front right side of the machine and has a multi gear assembly to it.
It can be mistimed, there are 2 holes and an arrow on the bottom that must be aligned.
For service, to save money. you can contact a service dealer or an ASP in your area that would charge you far less than Xerox. If you don;t know who those service providers are, just let me know what your zip code is and I can look up the nearest ones for you.
Posted on May 28, 2009
System error 09,005.40:143310 Xerox workcentre c2424
You either have jammed ink sticks or a bad Ink Loader 200-4711-80
It is fairly easy to replace, if you can get the covers and Document feeder off.
Whit
Item, Inc.
May 06, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error 37,008.4x
Most likely yes. That contains the power supply for that heater.
Oct 27, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Oct 22, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Jul 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
C2424 System Error 07,010.43
You have an E-mail address, I can send you the info.
May 15, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Error message
gearbox error refering to the printing tilting. probably have to have a service call
Dec 12, 2007 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
134 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
