Question about Fuji FinePix E900 Zoom Digital Camera
Camera powers down when pressing shutter button
When I press the shutter button the camera powers off. Is it possible to send the camera out to have the shutter button fixed or replaces Same thing. Suddenly after more than a year of usage, when I press the shutter button to take a photo, the camera powers down. Pressing the power button adjusts the lense but I still cannot take a photo.
    President:
  • 423 Answers
I see this frequently on the E900. Every time it has been a battery issue. If you're using rechargables (the E900 came with batteries and charger in the Canadian market......not sure about the rest of the planet), they may have just worn out over time. Replace with new NI-MH (nickel metal hydride) rechargeables. If you're using throw-away AA's, try Energizer Ultimate Lithiums. I've solved many, many E900 shutting off problems simply by changing the batteries to Energizer Lithiums.
Posted on May 27, 2009
I confirm Steve5's solution to this problem. E900 comes also in Italy with a small recharger (5 hours timer) and two rechargables AA 2300mAh 1.2v. I experienced the problem after using some old - and probably exhausted - rechargable batteries (1300mAh). After replacing them with the original ones, all works fine. I only hope that such behaviour can not cause some problem to the camera.
Thanks for the solution!
Posted on Sep 06, 2009
I hve transfered all the photos from my Hero 16 MG disk to my PC. it is still not allowing me to take new photos and videos just indicating "Full"Unclear how to erase my disk. Any assistance you could
Here are the steps to reformat your SD card with your HERO3 camera:
  1. Power ON your camera with the SD card inserted.
  2. Press the front (Power) button repeatedly until you see the wrench icon on the camera's screen.
  3. Press the top (Shutter) button one time.
  4. Press the Power button repeatedly until you see a trashcan icon.
  5. Press the Shutter button one time to select the trashcan icon.
  6. Press the Power button until "ALL/Format" is highlighted.
  7. Press the Shutter button one time to select "ALL/Format".
  8. Press the Power button until "Yes" is highlighted.
  9. Press the Shutter button one time to select "Yes". Your camera's LED and the trashcan icon will blink to indicate that your SD card is being reformatted.
Once they stop blinking, power OFF/ON your camera, and your file counter should show 00.
Important - Take a picture. This confirms that your SD card is successfully reformatted.
Sep 19, 2014 | GoPro HERO3 White Edition Action Camera
How to use the shutter timer on the canon power shot A620 camera
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button.
Feb 27, 2011 | Cameras
When i press the shutter button to take a photo the shutter goes up and the power goes down. i have to remove the battery (sometimes wait a few seconds) reinsert it and then the shutter closes. It does not...
If your camera battery is having limited current factor, there is a possibility that the entire action is not happening with the available voltage/current. as multimeter test of voltage might indicate the voltage but the current factor will need a series test. hence I advice you replace the batery and test again. If the fault recurrs then the camera electronics is at fault, possible that the shutter mechansim is taking up power and stenching the cirrcuits to hang up. I feel the camera has to be open out to confirm the power hang.hope I could help.? Good day
Jun 25, 2010 | Cameras
How do you change the shutter speed on the finepix s5500?
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Mar 08, 2010 | Fuji FinePix S5500 Digital Camera
How do you change the Date Time Stamp in the GoPro Hero series of cameras?
Taken from manual:
SETTING THE TIME AND DATE
You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is
removed the time and date settings will be lost:
Symbol on LCD Screen Function
When you see "dAt" on the screen, press SHUTTER button to set the
time and date.
Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030).
Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 01 (January) to 12 (December).
Press POWER/MODE button to toggle from d01 (1st day of month) to d31
(31st day of month). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23
(11 p.m. military time). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59
minutes). Press SHUTTER to advance to next date setting.
1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance
for the settings menu.
EXITING THE SETTINGS MENU
When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
Dec 21, 2009 | GoPro Motorsports Hero GMHW50 Digital...
OLYMPUS CAMEDIA C-860L
If you find an online user manual for the Olympus C-860L camera, please tell me (send an email to "dave at burtonsys dot com").  Thanks!
In the meantime, try this...
With the data cable unplugged,
Open the sliding front to turn the camera on.
Press and hold the green button on the back, light up the LCD display,
Press the menu button on the top edge of the camera (the button farthest from the shutter button).  That should bring a menu up on the screen.
Press the menu button repeatedly to switch between menu screens.  E.g., press it twice to get to the resolution screen (SHQ / HQ / SQ).
Press the "+" and "-" buttons to move between menu items.
Press the shutter button to select/OK the menu item you have selected.
I hope this helps!
-Dave Burton
Apr 11, 2007 | Olympus Camedia C-860L Digital Camera
Shutter delay
If you have installed optional expanded memory, you may notice a delay between the time you press the shutter button and when the camera beeps. You can reduce this delay by pressing the button down halfway, holding it as long as necessary, and then pressing it down the rest of the way when you are ready to take the picture. The reason for this two-step shutter is to save battery power. After a picture is taken, compressed, and written to memory, the Sparc CPU shuts down to save the battery's power. When the shutter button is pressed halfway, the Sparc wakes up and stays in the ready state until the user presses the shutter button the rest of the way. Besides the delay in waking the Sparc, there is a variable delay which occurs prior to the Sparc being in the ready state. This delay is dependent on the amount of free flash memory.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Sep 12, 2005 | Epson PhotoPC L500V Digital Camera
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Fuji FinePix E900 Zoom Digital Camera Logo
372 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
