Question about Bunn-O-Matic Coffee Brewer GRW8
Coffee maker leaks
The coffee maker leaks under the water resavore when I make a full pot of coffee. there is a small hole where it leaks.
  • 189 Answers
Please contact customer service and a seal kit can be sent to you that should fix your leak-it is successful about 90-95% of the time.
Posted on May 19, 2010
Keurig pot doesn't give a full cup of coffee
Maybe you need to clean the pot with vinegar and water on full cycle. Sometimes if you do not have a water filter on your faucet, the coffee maker tends to come out with little mineral or metal particals from your water source. Which tends to clog up the small holes in the coffee maker where the water flows thru. This happens after a lot of uses. You may want to do this at least 3 to four times. I set up mine like I am going to make a full pot of coffee. Then also use a coffee filter to check the amount of gunk that is collected. I hope this helps. I ended up buying a water filter and do not have a problem any more.
Aug 27, 2014 | Keurig Coffee Makers & Espresso Machines
My keurig coffee pot is leaking from the despenser, there was a orange foam piece with a small hole in it...where does this belong?
If water leaks when you are using My K-Cup, put less coffee into it, to about half full. When it is too full, there is not enough room for the volume of water, so it overflows.
Sep 27, 2010 | Keurig B50 Coffee Maker
One spout is very slow with leaking
The spout is only a plastic with two holes, if the one is only leaking while the other is running corectly then you only need to clean it with hot water and a small brush the hole and the groove. the spoot can easily removed, or even emese it in a pot with hot water for 20 minutes then flash only water.
Jan 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
My Bunn coffee pot leaks water theres always a puddle of water under the pot.coffee pot is over half full
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Sep 13, 2009 | Bunn NHB Coffee Maker
MACHINE LEAKS WATER
Turn on machine w/o water or google the company
Jun 02, 2017 | Waring Pro WC1000 Coffee Maker
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Vanishing water
Is this problem happening by chance after you have used the maker? If so the heat from the previous use may be causing the water to steam from being so hot and thus causing the pot to be only half full. the hotter the maker the more water evaporates. You might need to let it cool down in between pots.
Joe
May 19, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Braun Coffee Maker Type 4093
it sounds like the hole at the bottom of the waqter tank is clogged. the fact that it is hot means the electrical parts are all working.
it should be an easy fix
May 18, 2008 | Braun Aromaster KF 400 Coffee Maker
Bunn-O-Matic Coffee Brewer GRW8 Logo
240 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
