Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
My LaCie 500GB Quadra suddenly stooped being seen by my Mac
I also plugged it into my Macbook, and it did not read it either.
  • randy_lori May 27, 2009
    Sorry,
    I do not understand most of what you described. This hard drive just quit working. I am noticing that there are quite a few other LaCie owners experiencing the same issue.
    I tried a new fire wire connection, and I also tried a different USB connection. I re-booted my computer (MAC) holding down the "option" "apple" "R" and "P" keys for three chimes. No luck.
    I plugged the LaCie into my Macbook laptop, and the laptop also did not read it.
    President:
  • 2,923 Answers
Sorry to inform you, but there's a possibility that the HD already quit working. There could be some sectors that became bad. But, if the HD icon is not mounting on the Mac screen, that doesn't mean that the HD is already defective. You may follow the steps below:
If you are using a Mac Tiger (10.4.X) or Mac Leopard (10.5.X), here are the steps:
1. Connect your hard drive (HD) to the computer using either USB or FireWire cable.
2. Click the 'Go' menu (located neer the Apple icon, Finder, File, Edit and View).
3. Select 'Utilities' and then click on the Disk Utility icon.
4. On the left side of the window, check if there's a HD that will show up that is around 4.98GB or almost 500.
5. If there is, click it because it could be your LaCie 500GB. And once you click it, you will see if the HD is healthy or unallocated disk space.
6. If it showed up as 'Unallocated space', meaning, you need to reformat the hard drive.
NOTE: Reformatting the hard drive will erase all the files inside of it. You may bring it to the nearest data recovery center in your area (any computer store that offers data retrieval).
TO REFORMAT YOUR HARD DRIVE:
1. After locating the HD under the Disk Management, click the HD on the left side panel of the window
2. Locate and click the 'Erase' tab.
3. For the volume Format, select Mac OS (Journaled) - if you're going to connect your HD into Mac computers only. But if you're planning to use it in a Windows based computer, the volume format should be MS-DOS File System and the HD will be usable either in Mac or PC.
4. Volume name: you may put your name on it.
5. Click the Erase button and another small window will show up asking if you're sure to erase it.
NOTE: If the HD will not show up even under the Disk Management, then the HD could be defective. And again, there are some data recovery center that can crack and retrieve the important files inside your HD.
Good luck and have a great day!
Posted on May 27, 2009
    Brigadier General:
  • 3,917 Answers
ok is this on ur startup? (POST) does it say no HDD detected?
if so check the following:
ur HDDis set to master. therefore the little clip on the back and to the right is set over the master pins, this is diff, depending on what HDD it is, look on the top of the HDD it will say... also make sure if u are using ID-0 cables that u have it in the master plug, (the end one) also check to see if the cable is securely connected to the computer on the motherboard (i advise u to use a static grounding device btw)
then boot the computer and enter the BIOS. you click delete when u computer is booting up then check to see that the HDD is set as the main boot device, then cd the floppy.
Thanks
My Macbook Pro running Mountain Lion does not recognise My Lacie D2 Quadra V2 (301442a) after upgrade from Snow leopard
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Dec 02, 2017 | Computers & Internet
Upon start up I see the icon on my screen but then disappearing and reappearing along with all my other icon. the Lacie is disrupting my entire desktop & when I shut it down (Lacie) everything goe
I think the problem is because mounting problem of the logical drive .In this case to access your data in the drive you just need a macbook hard drive recovery tool .Remove the drive from your pc install the drive in some other mac pc and start it in target mode .Install this recovery tool and start recovering files but save it in different healthy drive .I am suggesting this tool because it works good for my missing partition problem.But purchase the full version to get good results.The demo version link is here...
Feb 03, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My lacie is making clicking noise like clock
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Dec 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Installed on MAC, then Plugged it to PC, now MAC won't recognize Drive
look into Disk Warrior...its a hundred bucks, but it is a miracle worker of sorts and might fix everything for you.
the frustrating thing about DW besides its $100, is it takes less than a minute to fix problems I would fret over for weeks
Dec 29, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
127 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
