Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Red color not showing and heavy yellow color on screen
I have a 50" hitachi LCD rear projection TV. The color is off. There are no reds and lots of yellow. What could be causing this? I have had the optical engine replaced twice.
electrotech1
  • 1126 Answers
SOURCE: My Hitachi 50V500 LCD rear projection LCD color
It is the convergence that needs change out and you looking at around 400 on repairs,
Posted on Mar 25, 2011
  • 579 Answers
SOURCE: Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Posted on Dec 31, 2007
  • 61 Answers
SOURCE: Hitachi 50" Ultravision too much yellow, not much blue
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Dals123
Posted on Oct 09, 2008
SOURCE: Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Posted on Dec 03, 2009
  • 171 Answers
SOURCE: my Hitachi Ultravision LCD rear projection 62
that is correct you need to replace the optical block to fix this problem the LCD chips are starting to burn out and the it why you are getting this problem reflecting on the screen this parts are around $230.00dlls to $340.00dlls plus the labor it is a thinker good luck I hope this was helpful
Posted on Aug 27, 2010
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blurry screen on 50in Hitachi LCD
Sounds like you need a bulb replacement, if you watch tv a lot ave life is about 5 years
Sep 14, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Color and foucus is not right.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Toshiba 50H72 50" Rear Projection...
Hitachi 53UDX10B no red color
The red cable from the cable box was loose.
Jul 20, 2008 | Hitachi 51SWX20B 51" Rear Projection...
HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Dec 30, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
304 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
