Question about Samsung SC-D103 Mini DV Digital Camcorder
Blank screen when in camera mode
How do i turn the demonstration mode off ?
Hi.
1. Remove the tape from the camera.
2. Close the tape compartment
3. Set to cam mode
4. Press Menu button
5. Press "enter" on initial
6. Scroll to "demonstration"
7. Press "enter"
8. Press "Menu"
done
Posted on Jun 18, 2009
How do i get the demonstration of the screen
There is usually an option in the menu to turn the DEMO off. Not sure the exact model number of the camorder that you are referring to. DEMO mode acts as a type of screensaver. It will start demonstration if the camorder is left sitting idle too long.
Hope this helps.
www.austintelstarservices.com
Jul 20, 2011 | JVC Video Cameras
My hd 3 v5061u is on test mode how do i get it off
With your camcorder powered ON, and set to VCR / playback, there should show on the screen (viewer) something indicating "Menu" or a "FN" (Function) option. Select "Menu" (or Function icon to lead to the Menu). Check through the Menu options to find "Mode", and find the option for Normal Recording or playback, as opposed to "Test Mode", or "Demonstration Mode".
If this does not solve the problem, try this: Turn the camera OFF, remove camera battery, re-install battery, turn camera ON and see if that Re-set the camera. If not, it might be resolved by manually resetting the time and date. Then go to the Menu again to set Mode to normal recording or playback.
If those do not correct the problem, there is no shame in calling the camera company to speak with Tech-services. That's what they are there for.
May 16, 2011 | HP V5061u Digital Camcorder 3...
Whenever i turn off the mains, i get a Demontration message after power on.
From the manual:
Demonstration Mode
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH
DEMONSTRATION PLEASE PRESS POWER KEY
WHILE THIS MESSAGE APPEARS IN THE
DISPLAY THANK YOU”
To cancel the demonstration
Press ?/1 to turn the receiver off while the above message
is being displayed. The next time you turn the receiver on,
the demonstration will not appear.
To view the demonstration
Hold down SET UP and press ?/1 to turn on the power.
Notes
• Running the demonstration will clear the receiver’s
memory. For details on what will be cleared, see
“Clearing the receiver's memory” on page 15.
• There will be no sound when the demonstration mode is
activated.
and...
Note: If the AC power cord is disconnected for about two weeks, the receiver’s entire memory will be cleared and the demonstration will start.
Mar 17, 2010 | Sony STR-DE445 Receiver
Front display is currently in demonstration mode How to turn off?
why i turn on my camera it says on the screen front display is currently in demonstration mode.
to exit: shutter button
and when i try to upload the pictures to my computer my computer doesn't read my camera.
Feb 08, 2010 | Samsung DualView TL220 Digital Camera
Blank screen
Try this...if you can still get into the setup menu, scroll to "reset" and follow the on-screen instructions. If not, remove the memory card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. Did that help?
Sep 28, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
My navman icn 510 is always on SIM
Your Navman is in Demonstration mode and is demonstrating a route that you have set up. It should be flashing SIM alternately with the time taken on the route so far.
If you don't want the 'Demonstrator' to operate, you can turn it off. See your manual. If you have not got one, you can download it from the Navman site.
I only have the iCN510 and I have to go to the main Menu screen, tap 'Route Information', then Cancel Route to cancel the current demonstration.
To turn off Route Demonstrator from Main Menu icon_arrow.gif Settings icon_arrow.gif Routing icon_arrow.gif next screen icon_arrow.gif Untick 'Demonstrate Route. icon_wink.gif
_________
Oct 23, 2007 | Navman ICN510 GPS Receiver
Philips magnavox fw-c1 3cd, 2 cassette, am/fm stereo
To stop the demonstration mode
• Press and hold stop (on the system
only)
for five seconds when the
system is in demonstration mode.
ª The demonstration will stop.
ª "DEMO OFF" is displayed.
ª The system will switch to standby
mode.
Feb 27, 2007 | Philips FWC1 CD Shelf System
Samsung SC-D103 Mini DV Digital Camcorder Logo
634 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
