Question about Refrigerators
No water in the ice machine
Water is spraying on the outside of the refer when the try tires to fill
  • Refrigerators Master
  • 4,655 Answers
Make and model please, Thanks, Sea Breeze
Posted on May 28, 2009
Icemaker leaking water into ice bin during fill cycle
HI,
Need more information like model number as all units are not same and the answer could be different for each unit. Refer, ice machine, Freezer, all different unit and run differently. Please allow me to help you with the correct information. Thanks
Apr 15, 2016 | Refrigerators
My Scotsman CE33A cycles on and fills with water then within 3 r 4 minutes the water volume goes down and wont spray up into mold.i can fill the resivor with water and it does fine until the water lev
In the water reservoir there is a tube that maintains the water height during operation. It fits in the overflow drain hole and keeps the water level at the proper level. This tube is either not installed into the bottom of the reservoir properly or it is broken.
Hope this helps
Feb 12, 2015 | Scotsman DCE33PA1BC 15in Built-in...
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
Jun 03, 2012 | Amana Refrigerators
Water leaking on the floor when ice maker is on?
It depends, you need to check the ice maker to see if the mold is cracked and letting water leak out. Another more likely scenario is the fill tube where water comes into the machine has ice in it and causing the water to spray out everywhere except the ice maker.
Jun 01, 2012 | Refrigerators
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
I just received a Sunpentown model IM 100 from a friend with no instruction manual. I?m not sure where to put in the water in the ice maker. Also there is a plastic male threaded drain on the left side of...
The outside male thread drain should have a cap to hold the water; this is the drain for draining the unit. Filling the unit is as you described, simply lift the lid and add water into the tub. It should not be leaking water from under the unit ... that could be a problem. Good luck!
Dec 05, 2010 | Sunpentown SPT IM-100 Portable Ice Maker,...
My franklin chef FIM200 is dripping water from the back, right side. The water fill valve was spraying out above the tray, we managed to get that under control, but, water is dripping right behind that...
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
Nov 24, 2010 | Franklin Industries Franklin Chef FIM200...
We have a Frigidaire Gallery side by side frig. We have had many problems, but yesterday it froze up with icicles hanging and big chunks of ice. My husband cleaned it out and thought it was OK. We woke...
First thing to check is where the ice maker actually fills up to make sure that its not full of ice and causing an over spray of water into the machine. You can actually take the tube out from the back of the machine. If there is no ice in the tube, next thing to do is make sure that the ice maker isn't over flowing and calling for to much water when its filling,. You can do this by either removing the ice maker and visually looking or by reaching in and feeling to see if the ice maker is completely full of water. If it is then either your ice maker is going back or the water valve is not closing when the ice maker is done calling for water.
Nov 07, 2010 | Frigidaire Refrigerators
Ice maker - Ice cubes are connected together instead of one at a time. Can this be easily fixed?
Good day,
By design, the cubes are fused together when they form. The water enters only the rear of the ice maker when it is filling, and flows forward one cavity at a time, thus leaving a small section connecting the cubes together.
In theory, the force of ejecting the cubes, and falling into the bucket causes them to break apart.
It's not perfect, but usually works most of the time.
If the machine or ice maker is not level, it is possible some of the wells get more water than others, which could cause the cubes in one part to be too large and create the problem.
The other possibility, is the water valve in the bottom back of the machine to not close promptly during the fill cycle causing the well to fill too high causing your issue.
A very remote possibility usually associated with homes that use well water, is the water pressure is too high, adding too much water per cycle.
Unlike a cloths washer, the ice maker uses a simple timed fill method which is normally 7 seconds.
An outside possibility exists that it could be an internal problem with the ice maker itself, but I've never seen that as an issue.
Sep 27, 2010 | Maytag Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
