Question about XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic Card
Red lines on display
We are trying to remove red lines that run from the top to the bottom of the display screen.  We have done a restore, changed drivers, wires and monitor.  The lines are pretty parallel, like pinstripes.  Any ideas or suggestions?
  • 104 Answers
Re: red lines on display - XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic Card Graphics Cards
Replace the video card.
Posted on Oct 21, 2007
0 characters
3 Points
Thin red lines have appeared on my samsung 42" plasma tv screen, I've taken it to a reapir guy who said the bottom board had gone and the top board was on its way out he wanted to charge £290.00 to...
There is no term called top/bottom borad in monitor. Lines might have caused becoz of capacitor problem in ur monitor. replacing capacitors will not cost much. try taking ur monitor to someother person
Oct 26, 2010 | Graphics Cards
Screen view of internet pages
Set also the settings of your Display Properties to 1024x640 or higher to achieve the maximum view of a website..
Fixya me on this idea.
Feb 10, 2008 | Graphics Cards
Lines running down screen - have tried different monitors and same problem - have changed ram over and problem persists - am thinking it either display driver or graphics card
If you have not made any changes to your system and the problem has surfaced apparently without cause, the graphics card is the most likely suspect.
However, when troubleshooting, go back to check any actions you may have initiated just prior to the appearance of the problem.
For example, if you have relocated or reconnected monitors (or cables were stretched) just prior to the problem, check the port on the graphics card for bent pins. If you just updated a driver, remove it. If you have experimented with display settings in Windows control panel or just replaced a graphics card, check Display Properties - Settings, particularly the screen refresh rate in advanced settings (reduce refresh rate).
Any of these issues can cause the symptoms you describe, in addition to failed graphics cards and faulty drivers.
Mar 08, 2010 | Graphics Cards
My medion akoya MD 96970 laptop screen displays multiple screens that tile down the page. its shows about 8 screens that have lines running through them. i have tried system restore and a disk error scan,...
well, i have to upset you. if your medion laptop shows you six screens instead of one and each one of them is somehow not clear enough it means your graphic processor is down, if your laptop is still on warranty send it to get your mainboard replaced with a new one, with an newer graphic processor installed. I acctually work as an service engineer for medion and in this model it is a common problem, every gpu is broken from the beginning and it is only a matter of time until it will burn. If you are thinking abt buing another medion laptop, think twice or buy those newer ones like p761x, s561x or so..
Mar 03, 2010 | Graphics Cards
Geforce 3 analog output: I have horizontal, blurred/faint lines scrolling from bottom to top of display, spaced 6 inches apart.
what kind of monitor? Have you replaced the cable? Try the pc on another monitor. You need to see if it's actually the monitor or the video card. replace the broken or defective part.
May 30, 2009 | Nvidia 64MB GeForce3 AGP Video Card with...
Vertical lines o my desktop
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
Nav4_disp conflict?
The nv4_disp fix I was able to successfully restore my computer to tip-top shape in 5 easy steps. Here’s my 10 minute solution.
  1. Boot your computer into Safe Mode w/ Networking. For Windows XP users, this is accomplished by pressing F8 repeatedly when your computer is booting up. You will be presented with several options. Choose “Safe Mode w/ Networking.” This will boot Windows XP into Safe Mode, but you will be able to browse the Web.
  2. Go to NVIDIA’s Web site and download the latest display drivers for Windows XP. I saved the 20MB file to my desktop for easy locating later on.
  3. Remove the NVIDIA display drivers currently installed on your machine. To do this, right click on “My Computer,” then select Properties. Click the “Hardware” tab, then click “Device Manager.” You now see a list of hardware devices installed on your computer. Double click “Display Adapters.” You should now see your NVIDIA card listed. Click it once to highlight it, then click the “Uninstall” icon in the upper right of Device Manager menu. Say “peace!” as the NVIDIA drivers are removed from your machine.
  4. Install the updated NVIDIA display drivers. Double-click the NVIDIA setup file you saved to the desktop earlier. The installation will run its course.
  5. Reboot your computer.
After following these steps, Windows XP should start up as usual (prior to our little nv4_disp bug). Your “nv4_disp” problem is officially solved.
What caused the nv4_disp problem? In short, I have no idea. I’m actually still trying to figure this out, so I welcome any comments about what could have been the cause. In doing some quick searches across the Web, however, I see that this is actually a common problem.
Mar 06, 2008 | PNY Verto GeForce PCX 6600GT, (128 MB), (3...
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
XFX NVIDIA GFORCE2 MX 200 (64 MB) Graphic Card Logo
620 people viewed this question
Top XFX Graphics Cards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a XFX Graphics Card Expert? Answer questions, earn points and help others
