Question about Freezers
I have a whirlpool refg. with built-in ice maker model# ED25DQXDW02. Everytime the frig. goes to fill the tray it fills it then over flows some. Is this a problem I can fix myself.
  • 56 Answers
Probably have to replace the icemaker take it out and look at the mold and see if you have some teflon coating that has come of and or some water deposit buildup under im on heater on bottom of icemaker. this causes it to let the water drip down on the back of im an causes iceblock in the dispenser bucker. you can order an icemaker 1- 877-262-1479
Posted on May 30, 2009
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Have viking side by side referagator , freezer model # ddrb304. I installed copper line to ice maker yesterday It is not making ice. Checked that water supply is on. Appreciate any suggestions Lou
make sure you have strong water pressure to the frig.
Do the ice maker have a shutoff arm? or a shutoff switch? either way make sure it is on. by now there should be water in the icemaker tray. if not then manually pour 1/2 cup of water into the icemaker. if it does make ice then replace the water fill valve.
if there is ice still in the ice maker tray you still have to check the water fill valve before we can say the icemaker doesn't work.
need a meter to check the continunity of the water vavle. if the valve is open repalce valve, if there is continunity the the valve is good.
hope this is helpful. if you cant do this ask a friend who is an electrician to help you
Mar 27, 2010 | Freezers
Kenmore Coldspot Model 57577791 S/S Ice Maker Problem
Probably the solenoid (electric valve that opens when the ice maker calls for water ) is leaking and has to be replaced (it's a very common problem ) . To be sure the solenoid is the problem , turn off the ice maker by raising the arm up , and check after a few hours if is any water in the ice tray , if yes the solenoid is leaking , if not , the ice maker control board has a problem , and to replaced it will cost you almost as a new ice maker.
Oct 19, 2009 | Freezers
Ice maker not getting water
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
Aug 17, 2009 | Whirlpool Freezers
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Apr 05, 2009 | Whirlpool Freezers
Freezers Logo
193 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
