Question about Canon PowerShot SD1000 Digital Camera
Memory card is locked w. Canon Powershot SD1000
Hi, I have a Canon Powershot SD1000 and I used to have a 2GB memory card. However, when I went to a friend's house for a housewarming party and I left my camera on the table. When I was about to leave the camera was gone. So I did some investigating and figured out 2 girls stole my camera. When I reluctantly got it back from them, my memory card was jammed in the wrong way and it said my "card locked." I tried the switch on the side of the memory card, but that did not work. So I thought those girls broke my memory card. So I bought a 4GB memory card instead. I thought that was going to work because I thought those theives just broke my memory card. Now with my 4GB memory card it says "card locked." My questions are: Is there a switch inside the camera that causes the memory card to be locked? Or is my memory card too large for my camera? Or do you think my camera is broken and now needs to be fixed?
    President:
  • 423 Answers
Your Sd1100 is compatible with a 4gb card, so that's not the issue. If the lock-switch is in the correct position, the only logical conclusion (which you have already come to.....good troubleshooting on your part!) is that the camera is busted. Send your two "friends" the bill. What a drag.
Posted on May 27, 2009
When I reloaded my memory card back into my Canon powershot SD 1000 the LCD came up saying Incompatible JPEG even though I have been using this memory card right along?
Did you maybe copy some jpegs onto the card from another source? If the contents of the memory card is no longer need, take the card back out and run a quick format through the computer
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
Have canon powershot what is best to use a 2gb
Hi and welcome to Fixyah,
I believe that canon can only use SD card you can used 2gb sd card.
Mar 18, 2010 | Canon PowerShot S2 IS Digital Camera
My Canon Powershot sd1000 is locked up. It turns on but will not take pics and I cannot view images. It is locked on one picture.
Check the lock switch on the side of the memory card. That is usually what causes the situation you are describing. It may have moved to the locked position accidently
Sep 27, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
Memory card compatibility
Yes, SDHC memory cards are compatible with the Canon Powershot A700, so that means you can use card with capacities over 2GB. You can also see the manual to verify this, Canon Powershot A700 Manual. On page 8, it says that SDHC memory cards are compatible.
Jan 02, 2009 | Canon PowerShot A700 Digital Camera
Canon sd1000 card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 03, 2008 | Canon PowerShot SD1000 Digital Camera
Card locked
Have you tried looking at the memory card? Sometimes there is a switch on the card itself that slides up and down to lock, or unlock the card for usage. Hope this helps! (It should be white, and a semi-translucent plastic.)
Sep 24, 2008 | Canon PowerShot SD1000 Digital Camera
Memory Card
b32f20a.jpgPowerShot SD630
Camera will not power on with a memory card installed.
1. Try another memory card and contact the memory card manufacturer 2. The PowerShot SD630 requires repair service.
This information sourced from Canon Support Forum page here
Jun 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Unidentified Images.
I would try formating the card using the camera (menu - setup - format) - THIS WILL ERASE ALL THE PICTURES YOU CURRENTLY HAVE ON YOUR CARD, so before you do this you may want to get a memory card reader and transfer the pictures (click and drag) to your computer. As to using the 4GB card...you will have to check with canon if a card that size if compatable. Not all cameras work with SD cards larger than 2GB.
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Canon PowerShot SD1000 Digital Camera Logo
303 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
