Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Wash cycle taking way too long, like 90+ minutes
My LG front load washer's 58 minute wash cycle takes 90+ minutes. It hangs on the 58, 57 part of the cycle for a really long time. Any suggestions on how to reset or get it to work properly again?
    President:
  • 1,902 Answers
You timer is bad and needs to be replaced. Your problem is a common error and is something a lot of people on here run into. You can go to repairclinic.com and get this looked at
Posted on May 27, 2009
How to shorten the wash time in this Siemens washer
There should be a speed load or 30 minute fast wash cycle
Jan 19, 2014 | Siemens WFXD8400UC Front Load Washer
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
Wfmc3200uc101 bosch washer doesnot spin out when a single sweater is in. the drum turns but not at full speed
i have the same problem, what i find helps put a bed sheet in with the sweater to even the load, ( I keep a sheet by the washer for this specifically) and take it off max. spin cycle for the small load (I know this sounds stupid) I have a bosch also and I have problems with small blankets too. This usually helps, but I found that if i do this under the 25 minute quick wash instead of the regular wash it doesn't spin out either, kind of stupid to run a machine with only one sweater for 58 minutes, I would never buy a front loader again, betty
Jan 21, 2011 | Bosch WFMC 3200 Front Load Washer
Cycles take an exceedingly long time to complete
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
Sep 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes. The cycle says 50 minutes but it ends up taking 75 minutes.
This is really not uncommon. The more and more sophistocated the machines become, the more small decisions they make on their own. I have seen a one hour load take up to 2.5 hours.
If a load is off balanced, it will change the time. If the spin cycle doesn't spin enough water out, it will increase the time, and may still be too wet. (In that case you need to clean out the lint/drain trap.)
If you really want more control and quicker washes, there will be a setting like "Quick wash " or "Fast wash." Theis setting is quite basic and does exactly what you tell it to do, and you can always add and extra rinse, or higher speed cycles.
Kenmores and GEs are the highest reported rate of longer times. Relax. The more you add, ie, delicate, two rinses, light spin, medium dry, the longer it will take. It's just trying to do its job! :)
Sirwriter
May 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG Front Load Washer
This model automatically detects the load size and optimizes the washing time however I do not believe the it should get stuck as you say... try this.. load the washer and then using the control knob.. select Normal.. then push the Quick cycle button on the right.. select the soil level button until it displays 31 minutes.. and run that.. if after you run a wash load it continues to display or get hung up on a specific number such as 7.. your control board may be defective.. If its warranteed.insist they replace it.. Hope that helps...
Aug 10, 2008 | LG WM-2277HW Front Load Washer
When doing quick wash "25 minutes" why does it take an hour?
one think comes to mind if you have extra rinse selected un select it all preset cycle times arent based on extra rinse
Sep 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
679 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
