Question about Refrigerators
Viking fridge water and ice not working
I have a Viking 42'' built-in fridge. The ice maker isn't getting any water and the water dispenser not working either. When the button is pushed, I can hear the pump engage but nothing comes out. Could a clogged filter cause this problem?
    Problem Solver:
  • 18 Answers
Yes....a totaly clogged filter COULD cause the problem, but the water solenoid may be the culprit. I'd call a service company to look at it.
Posted on May 29, 2009
What is the problem that ice maker is not working. Why the ice cube cannot make? Even I changed the water filter.
There are two solenoid valves usually at the bottom of fridge in the back. These valves control the water to ice maker and water dispenser. They are replaced as a set. This is the first place to look. Generally this valve goes bad and solenoid does not open when ice maker signals it to open.
Oct 06, 2016 | Viking VCSF036DSS
How do I remove a Viking side by side refrigerator from the wall cabinet it is in?
There are adjustable wheels on front. Jack up front enough to grab the frame and pull out slowly. Be careful if you have water line for ice maker.
Dec 03, 2014 | Viking 42 in Built In Professional...
Not dispensing ice
Try turning it off for 12 hr's. Buy the 5 yr. warranty on all ref. with ice maker
May 21, 2014 | Viking 42 in Built In Professional...
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Water dispenser and icemaker not getting water on a maytag fridge
pull line off of the back of fridge to see if water comes out if not its where ever you have that line taped into yuur water supply for the fridge had the same problem hard water clogged up the tee off take it off poke some thing in the little hole make sure you have the water shut off to the water supply when was the last time you changed the filter in you fridge it could be tht too
Nov 12, 2011 | Refrigerators
My water dispenser and water to ice maker isn't working. any suggestions?
my monogram ice maker wont make ice. it is on, the water fills the pan but thats as far as it gets. the area is cold. the hoses appear open. i have cleaned the dust of the compresser. what else can i do before i call the repair man?
Jun 15, 2010 | GE Monogram ZISx420DR 42-inch Side by Side...
Still leaks
it is condensate from the auto defrost bin/drain pipe,locate and clean with clorine bleach(stops nasties growing....)
Jun 02, 2010 | Viking 42 in Built In Professional...
No ice
put your finger into the mold of the icemaker or get a mirror and see if there is any water in it, if not, pour 5 oz. of water into the mold and wait approx. 2 hours, if ice dumps out then you have a water supply problem. the fill tube line entering the the mold could be iced up, if it is then your water valve maybe leaking and freezing up. also the water valve may not be opening up and may need to be replaced if it still doesn't dump out the water you poured in the you will have a problem with the icemaker itself
May 07, 2009 | Viking 42 in Built In Professional...
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Refrigerators Logo
597 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
