Question about Microsoft Bluetooth 5000 Mouse
I have a Microsoft Bluetooth Notebook Mouse 5000 and i need to change the battery. I cant find any latch or button to open the mouse to put new batteries in it! I looked on the MS site and found nothi
I have a Microsoft Bluetooth Notebook Mouse 5000 and i need to change the battery. I cant find any latch or button to open the mouse to put new batteries in it! I looked on the MS site and found nothing. Help. Where's the secret compartment?
There is actually no release button on my 5000. Between the white on-off button and the bluetooth synch button there is a finger notch. If you put your index finger in the notch (pointing toward the base of the mouse you can put your nail under the lip and the batter compartment opens right up. There is a horizontal slot in the battery cover - trying to pry that open does not work. The whole thing is well-cloaked but surprisingly easy when you figure it out!
Posted on Dec 22, 2009
  • 1 more comment
  • suzibeau Feb 18, 2011
    thank you! this was so much more helpful than the Microsoft documentation. I was about to get frustrated and do something stupid. Already had a screwdriver out....
  • rose porter Nov 14, 2011
    This was the best advice and it worked just perfectly. Thanks
  • Lorrie.Martinovich Mar 03, 2013
    Me too....was getting pretty frustrated
    President:
  • 623 Answers
Remove the battery cover from the back of the mouse by sliding off the cover while pressing the release button at the bottom of the mouse.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 27, 2009
  • 696 Answers
If I remeber correctly yhe button is at the back of the mouse and covered by a symbol, it is a hidden button that will pop the battery casing open like a fuel door on a car.
just follow the centerline past the word microsoft to find it.
Chris
Bluetooth Notebook 5000 Mouse will not connect. The green light comes on and then goes off. The bluetooth light on the laptop is on. Just changed the batteries. What to do?
You may just need to re-PAIR it. You need to press and hold the Pairing button until you get a solid blue light then it is in pairing mode, you can then discover it on your laptop and complete the pairing.
Jul 12, 2010 | Microsoft Bluetooth 5000 Mouse
How can i remove the battery of my microsoft mouse 5000
I found this page about that particular mouse: if you look at the images part way down the page (may have to scroll down a bit) the middle image is of the bottom. There is a little trap door for the batteries. There is a little catch you just push on the release and the door opens. Very easy.
May 31, 2010 | Microsoft Bluetooth 5000 Mouse
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
Red and green light flashing of microsoft mouse 5000
The first thing that I would advise you to do is,
Uninstall the Bluetooth Adapter driver totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Bluetooth Adapter).
After this, Press your ON/Off button on the mouse and ensure that it is On, then try to use it again.
It should connect like that.
(In case you dont know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under bluetooth/network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Nov 24, 2009 | Microsoft Bluetooth 5000 Mouse
Blinking red and green
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
Oct 28, 2009 | Microsoft Bluetooth 5000 Mouse
How do I open the microsoft 5000 bluetooth mouse to change the batteries?
Press the small silver button on the back of the mouse. When you press this in, slide the top of the mouse backwards and you should see the battery compartment inside. Hope this helps!
Oct 24, 2009 | Microsoft Bluetooth 5000 Mouse
Microsoft blue tooth 5000 mouse stopped working
Deleted the mouse from bluetooth and then added again.found info at
http://support.microsoft.com/kb/894035/#top
Jun 13, 2009 | Microsoft Wireless Laser Mouse 5000
I have a Wireless Mouse 5000.
Is this a Microsoft Wireless 5000 Mouse? The battery plate should be on the bottom of the mouse to take off to put in the batteries, similiar to a TV remote contoller. And it can be latched pretty tight.
Included a Youtube video of someone taking the battery out of his mouse.
Jan 29, 2009 | Microsoft Wireless Laser Mouse 5000
Microsoft Bluetooth 5000 Mouse Logo
14,878 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
