Question about LG Shine KE970 Cellular Phone
My screen wont work!! :s
The screen lights up with a backlight when i turn the phone on but it doesnt display anything, could anybody let me know of any suggestions please. thanks
  • liamclarke3 Oct 23, 2007
    do you know the uk number for the LG care centre?
  • 452 Answers
Hav u dropped ur h.set ?if yes contact lg  care center. if not then take the back up of data & reset ur h.set .check display settings & try to set some theme.
Posted on Oct 23, 2007
Inner display backlight works, but it doesnt display anything, could this be the cable sockets problem? Thank you for help.
If you look very closely (check in different lighting conditions), do you see anything on the outer screen at all? You probably won't be able to fix this yourself, but you might be able to determine if something is loose. Press a button on the phone, which would normally make the outer screen light up. Hold the phone firmly in one hand and smack it into your other, outstretched hand at different angles (i.e. smack the right side, left side, top, etc. several times). If the screen comes back on even for a moment, then something is just loose, and the repair shouldn't be costly. If you can see a faint image on the screen in some lighting condition, but smacking the phone doesn't help, then the problem is the backlight and you will probably need a new screen. If you can't see anything on the screen at all, and smacking doesn't help, then the problem is unknown
go to nokia care
Nov 22, 2014 | Nokia E90 Cell Phone (Unlocked) - Black
Backlight problems for E71
i think you have a backlight problem....can you just see whats on the screen if you put a light up close to it. or is it dead. either of them... can be fixed but it will cost a little for repairs. get someone to do it. because there is a lot of delicate soldering to be done...
Nov 12, 2009 | Nokia E71x Cell Phone
Phone turns on, backlight comes on but screen wont work
frist wash the petrol and assid 2 check the display ok any more sent me mail
Aug 24, 2009 | Cell Phones
The screen light on my phone doesnt work
More than likely, you've turned the back light off all together. Go into the menu, and display settings and find the backlight options.
If it's set to 'on' and to stay on for at least 3 seconds, yet nothing works: turn your phone off and then back on again. If still nothing, take the battery out, put it back in and start it up again.
If there's still no backlight, contact your supplier or the store you bought it from.
Jul 25, 2009 | Motorola Mobility V265
Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
May 19, 2009 | Acer Aspire 5315 Notebook
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
Mar 10, 2009 | Dual Car Audio & Video
My pantech duo phone doesnt work anymore!
From the way it sounds, mine started doing this yesterday. Everytime i turn on the phone, theres just a backlight and nothing else. well the only way i noticed to get it to work, atleast until i can get a new phone is, to leave it slid up because it wont do anything if its closed or slid sideways. And while it slid up, I either have to call it from my home phone or recieve a text message. I'm not sure why but that made the screen come on so I could atleast check everything. It doesnt always work but it does most of the time. I hope this helps. Just play with and figure out what it takes to get your screen on. I'm not sure how to permanently fix it though.
Feb 10, 2009 | Pantech Duo Smartphone
Problems with my motorola v3x
if the display on your screen is only half of it, it means that the theme installed in your fone is not for motorola v3x.
with regards to the backlight, the connector from the lcd to the board is loose.
if you can only see the white light, it means that your fone is running an application, loading or hanging up like what's happening in pc's.
i think you need to master reset your phone and put only a 256memory card. even though it is said to carry up more, just stick with the 256 memory to avoid those problems.
Oct 28, 2008 | Motorola Mobility RAZR V3x Cellular Phone
hi!! with regard to your problem stated it seem that you have a flex problem! if you know have to change the flex of your phone you can try purchasing on ebay. but the safest thing to do is bring your phone to a repair shop, better if you can bring it motorola service center where they can handle the repair with no problem!
My sidekick backlight
Is it the LCD back light? If so, it probably burned out. Did the phone get wet recently? That is usally the main cause.
You can get a replacement screen on ebay for about 40-50 dollars. Look for ones that come with the instructions and screwdriver. You will need a T6 Torx Driver.
Replacement Sidekick LCD Screens
Jan 19, 2008 | T-Mobile Sidekick® 3 Cellular Phone
LG Shine KE970 Cellular Phone Logo
108 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
