Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Bad sectors of my hard drive
I think my WD 250GB hard drive has some bad sectors cause some files don't transfer well. Is there a way to fix this?
  • 34 Answers
There's no concrete way, you can try these software:
Posted on May 27, 2009
    President:
  • 1,383 Answers
Yes u can fix it.
u can fix it with disk checking
right clik drive and go to trools u see there disk check and clik on fix automatically error
then it fix eror on harddisk.
I fafter completing disk checking still error inn harddisk then first take backupo all data which u required thenm format it
My WD2500XMS 250GB has gone mad. It should have 250GB free space but it has 126MB(111MB free space) according to my computer. Tried formatting it however it did not change anything at all. Any ideas?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps you
Mar 19, 2012 | Western Digital WD Passport 250GB Portable...
External hard drive does not show up on computer reinstalled the drivers and got it to show the files a few times, tried to pull files off onto main computer and it would freeze up and then not show...
Bad sectors are very common. You can check if there are bad sectors with the drive using the free trial version of http://www.hdtune.com/
You can attempt to recover your data yourself using http://www.r-studio.com/
But if you have never done this kind of thing it can be complex. If you want data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Sep 21, 2011 | Western Digital WD Passport 250GB Portable...
Runs very slow,cant transfer filesfrom my passport onto my computer
Run WD's Data Lifeguard diagnostic utility on the drive... http://support.wdc.com/product/download.asp?groupid=203&sid=3&lang=en
If it shows bad sectors and you need your data back this guy can help you remotely... FreeDataRecovery.us
May 19, 2011 | Western Digital WD Passport 250GB Portable...
I have bad sectors on my 250 external hard drive and cann not access it. i get i/o error messages. how can i repair my hard drive
use window 98 cd boot ur system select 1st option start with cdROM support then type scandisc command it will recover all bad sectors
Feb 19, 2011 | Western Digital WD Passport 250GB Portable...
Keeps telling me to format it
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Feb 15, 2011 | Western Digital WD Passport 250GB Portable...
My Music folder suddenly deleted all the files in it, but the folder won't delete because it says it's not empty; however, it won't let me open it either. It keeps popping up an Error code 0x80070091: The...
You probably have a disk-drive with some "bad" sectors.
So, when you try to read the sectors that contain the directory for the 'My Music' folder,
that sector cannot be read, and thus Windows reports an "empty" folder.
It's probable that your disk-drive is about to _completely_ fail, not just _partially_.
Make a backup of what files & folders that _can_ be read.
Dec 11, 2010 | Western Digital WD Passport 250GB Portable...
I have issues while transferring files back from Western Digital 1TB external drive. I copied all my important files there. In explorer all files are showing, but have issue, when you want to open or copy...
Hard drive may be going south and there may be bad sectors on it. Run WD diagnostic program on it and cross your fingers. Do not format the drive - that will erase all. If you do find bad sectors the check disk program will find and block bad sectors and move data in bad sectors to good ones whenever possible. After that you can recover as much as you can but not all because there will be areas where nothing can be read at all depending on the severity of the damage to the sector.
Sep 12, 2017 | Western Digital MY BOOK HOME 1TB EXT...
WD Hard Drive File Recovery Question:
No that not true.
hi buddy i had already added the solution for that on my website i am giving u the direct link just check it out i am pretty sure it will work for u
http://fixmypcandmac.com/windows/others/How%20To%20Find%20And%20Recover%20Your%20Lost%20Files%20In%20Hard%20Disk,%20USB%20Drive,%20Or%20Memory%20Card.htm
Mar 14, 2009 | Western Digital 250GB MyBook External USB...
SimpleTech 500GB Hi-Speed USB 2.0 causing Windows to crash
Blue screen means hardware problem, Try to defrag your hardware possible bad sector problem. Just follow the procedure as follow: Click Start> Programs>Accessories>Disk Deframenter.
After opening fragment's system select the drive by highlighted the available drive and click defragment button. Just wait until done. It will automatically fix the bad sector if not so critical.
If the problem persist during the defragment, there is a critical problem with your harddrive.
Please rate me SOLVED
Nov 21, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
1,275 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
