Question about Meade LX200GPS Telescope
Well the RA Opto Interrupters are not working on the limits for the slew of the telescope...is not working and needs to be replaced...where can I get just these parts? thank you
For a MEADE LX200GPS Telescope Well the RA Opto Interrupters are not working on the limits for the slew of the telescope...is not working and needs to be replaced...where can I get just these parts? thank you
  • 3,186 Answers
Meade is the only place to get parts---
See their web site for Customer Support--
www.meade.com
Posted on Jun 04, 2009
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
CG5 is brand new-not 30days old yet. Mount slews before a star is selected for alignment and continues to slew about the RA until power is cut. What is wrong. Tried 2 different power sources and factory...
You should return the scope under warranty-- however a bad power supply-- and or a bad hand controller cable can cause these symptoms called a "runaway slew".
Get a separate 12 volt power supply and the proper cigarette lighter style power plug.
Feb 12, 2011 | Celestron CG-5 Mount Telescope
My telescope is only slewing at the max speed. as soon as i change it to another speed it will now slew??
Either the buttons are STICKING on your hand controller, or the hand controller cable is defective.
Contact Meade customer service:
http://www.meade.com/support/index.html
Aug 30, 2010 | Meade ETX-60 AT Telescope
I have a CPC11GPS telescope that was working the last time I used it, which was 6 months ago. It is in NEW NEW condition. I pulled it out last night, turned it on, allowed the system to align itself using...
The clutch is not engaging in RA. Maybe the gears are not actually meshing together? A loose worm gear?
You can open it up and look and see if anything obvious is loose. Otherwise it's a trip back to Celestron.
Dec 04, 2009 | Celestron Optics
I've made every possible alignment on my 10 inch Meade LX200GPS telescope, training,set-up, calibration, etc...but when I slew to a star....it is ALWAYS very far off in Dec....though RA seems to be well...
You might want to join the following Yahoo group:
http://tech.groups.yahoo.com/group/LX200GPS/
I am not familiar with the LX200, but there are probably folks on the Yahoo group that can help.  The only thing I can think of is if you are using a wedge and the wedge isn't at the correct angle (should match your lattitude).  Or you are not using a wedge and the Meade controller thinks that you are.  But one would think the calibration would solve that.
Apr 26, 2009 | Meade LX200GPS Telescope
ETX125 PE new model. Elevation has totally stopped.
Could be that the DEC motor driver has died. That could be verified by swapping the connections between the RA and DEC. If the DEC now moves, then that is the problem. If not, then the DEC motor is bad.
Nov 17, 2008 | Meade ETX Premier Edition: ETX105 PE...
RA will not track on Orion Atlas mount
Are you sure it's not actually working (tracking)-- can you hear the motor running?
I would contact Orion and make sure you have a manual for the hand-controller-- it may have a setting that turns tracking on or off.
http://www.telescope.com/control/main/
Nov 14, 2008 | Orion Atlas Mount GoTo Upgrade Kit...
GOTO ERRORS MEADE LX200 10" CLASSIC
Most problems tend to be mechanical. Have you 'trained' the drive and set the backlash values? Those 2 can have dramatic effects on pointing accuracy. Also, if the optical tube is not in alignment with the mount, then nothing will work correctly. To check that, have the telescope in Alt-Az configuration, inside the house, loosen the RA lock, and shine a laser pointer on the corrector plate. as the telescope is rotated about the RA, the reflected spot should be steady. Adjust the DEC to minimize the diameter of the circle that is drawn. What is left, is the out-of-true on the DEC axis. That can be adjusted with the tube cradle alignment bolts.
Oct 17, 2008 | Meade Optics
Meade LX200 10" - RA Gears slip when mounted on wedge (Milburn)
The problem is the addition of the 80mm telescope to the assembly. The telescope is now out of balance, and places extra weight off-center as the position chages. Too great an off-balance will cause the main gears to 'jump' the worm teeth. The solution is to restore balance by adding counter weights as needed. Loosten the axis locks (carefully) and see which direction it wants to move. To balance my LX, I used a small bag with lead buckshot to determine how much weight was needed and where to achieve balance. Then I added fixed weights to the mount. Once this is done, the scope should track correctly.scopestuff.com has balance kits at reasonable prices.
Feb 03, 2008 | Meade LX200GPS Telescope
Meade LX200GPS Telescope Logo
141 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Eric Hidle
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
