Adjusting screen on HD TV
When I am watching a non-HD program the screen is expanded where I can not see the score or ticker-tape that is running at the bottom of the screen. Example: when I am watching a football game in non-HD I often can't see the small box at the top of the screen that shows the score. I also can not see the scores that run in ticker-tape fashion on the bottom of the screen. However, if the game is in HD I do not have a problem seeing the box score and scores running on the bottom of the page. I have tried to play with the picture mode (cropping, zoom etc) but am not having any luck with adjustments.
  • Anonymous Feb 10, 2009
    Sam problem. Also have aproblem when connecting my mac to via hdmi.
    It crops all sides.
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Posted on Dec 19, 2007
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Posted on Oct 21, 2007
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
Phillips tv the view is too big for screen, so I am only seeing part of what is being shown. Watching sports and can't see score, or watching news and can't see ticker at bottom. Tried vertical adj and...
Make sure you are in the correct input. Did the installer connect the cable box to the television in two places? If so you'll want to choose the correct input of the two. Also make sure your cable box is set to the correct resolution for your television set i.e. if you have a 720p set it to 720p not 1080i and vice versa. Look for an hd zoom# button or format button or aspect button on your cable or satellite remote to adjust the picture size. If it is not on the remote the picture adjustment setting is in the menu/setup of your cable box or satellite box.
Aug 20, 2010 | Televison & Video
Picture doesn't fit on my Samsung HDTV
after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
Sep 21, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
I'm watching football and cannot see the top score
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes (www.totalcontrolremotes.com) for help with this kind of issue.
Sep 06, 2009 | Vizio 42 in. LCD TV
The ticker tape or lower banner is not visible on HD channels
It sounds like the TV is in overscan mode, thus chopping off part of the screen. Check your manual to see how you can change this mode. The mode also might be in 'Zoom', thus chopping off part of your picture
Feb 07, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Aspect ratio, cuts off edges of picture.(NOT THE T.V, THE RECEIVER!)
Dilon, 311's have no aspect ratio adjustment and is not able to switch from the standard 4:3 setting therfore if it is connected to a TV with a large screen the TV has to stretch the picture to fill the screen thus cutting off portions of the picture. I suggest you get a HD receiver as they will be able to change the format and aspect ratio but even these make some sacrifices to fill the screen as well. Most notable of the losses will be the ticker tape at the bottom of the screen where sports scores usually are displayed. Thhis is all a result of the plethora of screen sizes on the market and will not be resolved anytime soon that I am aware. Dish has a 211 which is a one room HD receiver, 612 which is a one room dual tuner receiver with DVR, 222 which is a dual tuner two room receiver with HD capability to the first location and SD to the second, 622 and 722 which are both dual tuner two room DVR receivers with HD to the first location and SD to second. I am sorry I could not bear better news but I wanted to thank you for using Fix Ya and if you need further assistance please let me know.
Jim
Nov 09, 2008 | DISH Network 311 DTV Receiver
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Wacthing sports -Tickers and scores are off screen in HD
skilled,senior tech needed to access servicer mode and check/adjust geometry/convergence. if unresponsive,then replace convergence and re-check geometry and alignment.
Sep 30, 2007 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
2,110 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
