Question about Onkyo HT510 Receiver
How can i deactivate ''protect mode'' on my Onkyo ht-r510 av receiv
My onkyo ht-r510 would not turn on. The three fuses i see on the insider are not blown. I removed all cables from the back, and tried to turn it on again. It came on briefly and then turned off, never to turn on again. From all that I read, it seems the dreaded protect mode was activated. I live in RI and there are no service centers near by. Is there a way to determine what specifically is involved in the ''circuitry'' that Onkyo says is avtivated to protect the system? The system was given to me and I am not going to pay to have it fixed. I would rather dump it and purchase a different make system that has a better service center network, than Onkyo.
  • aohinds May 28, 2009
    Last night i did two things.
    1: I move the receiver to a different wall plug.
    2: I reseated the fuses.
    It came on briefly when powered up and then turn off, following by several "clicking" sounds similar to the one it makes when it is powered on.
    Subsquent power on/off resulted in this "clicking" but no display. I left it overnight and tried in the morning, and the same thing occurred.
    What i am i looking at? a blown transistor? are they the white ones near the heat sync?
  • adrian_hinds May 11, 2010
    I did remove the three fuses to have a better look. Is there a right/wrong way to put back in? i.e. is there a negative positive end? just checking to see if i made the issue any worst.
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR500 5.1 Receiver Last night
1-disconnect subwoofer first and test-and then disconnect surround speakers-and front speaker after-and later center speaker.ever time you disconnect you check the operation until you find the bad one(or two)which make the problem change its cable first and then change speaker itself.if all above failed contact the service center.
Posted on Jul 04, 2008
  • 153 Answers
SOURCE: Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
Want to control my HT-R510 with my TV remote. Need Onkyo code to control this HT-R510
You should indicate you remote.
In any case, if code is not in your remote you should follow indications for No code
If you don't have a manual, look for one using google,and terms manual, make and model of your remote
Aug 26, 2015 | Onkyo Audio Players & Recorders
Onkyo HT-R510
have you tried to reset it to factory defaults yet? If it has a vcr button on the front, then hold the vcr button and press power...it should say reset on the front. Might not help, but worth a try.
Dec 04, 2013 | Onkyo TX-SR601 Receiver
Onkyo HT-R510 left side speaker garbled
Out put transister could be fried ,Or the speaker is blowin,
Nov 29, 2012 | Onkyo Ht-r510 600w 6.1 Dts Home Theatre...
Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Mar 21, 2010 | Onkyo HT510 Receiver
My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Dec 04, 2009 | Onkyo TX-SR501 Receiver
The HT-R510 unit's overheat protection kicked in
Hey there..Sorry.When the amps are over powered they blow the main circuit and short causing the amp to turn on the right back off to protect mode.That you will have to send in to get fix..Look behind the amp and see if theres any wires touching or grounding out.My favorite amps are from onkyo and believe me i've done this a few times to 5 aps I've had.So I up graded to the tx sr 906 It rocks and will blow every speaker I have before the amp will go..Hope this helps you and good luck..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 02, 2009 | Audio Players & Recorders
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
HT-R510 home theater system
If bought new return immediately for replacement. The amp section is no good and cannot be reset - needs repair. but you are under WARRANTY - use it.
Sep 06, 2017 | Onkyo HT-S490 System
Amp Protection Mode
no, your output transistors maybe 2 of them are gone or the small power supply that feeds the other circuitry has become defective.
Dec 13, 2006 | Onkyo TX-SR503 Receiver
Onkyo HT510 Receiver Logo
829 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
