Towards the end of the cycle lights 1 and 2 start to flash and water is left in the dishwasher
I used the solution above and my dishwasher now working!!! I would add, plenty of towels and a tray or three to catch the stinking water that comes out of the outfow when you tip it up. Yes 6 screws to remove the back, but on the Indesit IDL40 two additional longer screws in the centre are helpful to remove. Then just tuck the bit that was attached out of the way. My pump was cream and white - check out pumps online to see what they look like. Undo the one screw holding the pump in place and then you have to twist it to release three little pegs. I washed outs loads of small bits of grit. Then easy to put back together. Re-attach the drain pipe to your drain, electric plug at wall and water inflow pipe. (Check for leaks!) I am so happy! Took me two hours but I had to hunt for the info and find the hidden screwdrivers. Husband will be pleased I think.
Oh ... celebration too early. Stopped again before draining.
Tried cleaning again, and cleaning out the outlet bit on the inside with some soda crystals still no good,...so bourght and fitted a new drain pump......STILL not working...still same two lights coming on and not emptying....help appreciated
SOURCE: Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
SOURCE: Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
SOURCE: Indesit IDL40 Dishwasher
from indesit website http://www.indesit.co.uk/indesit/_pdf/manuals/19504287203_UK.pdf
SOURCE: Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
