Question about Pioneer VSX-D810S Receiver
How to hook the thing up and can it be hooked to a home computer
Please tell me exactly what wires I need to hook this thing up and if it can be hooked to a home computer please tell me how thank you
    President:
  • 2,992 Answers
You can download the manual from Pioneer at this page. Just click the "owner's manual" link. There are diagrams and hookup information in the manual.
It is possible to connect your computer. You can run an audio cable from the line out jack (the one that would normally connect to a set of computer speakers) and connect it to an available input on the receiver (such as the auxiliary or CD inputs). You would need to pick up an adapter or cable to provide the right connections at both ends. The computer will normally need a stereo mini-phone plug, and the input at the receiver is RCA plugs.
Posted on May 27, 2009
Purchased the LHB335 Network blue ray disc home theater system. Hooked it up with an HDMI cable. We can only get the surround sound to work thru the DVD player. We either don't know what in put to have the...
If you can take very close up pics of the back of the blu ray, and the connection site on the tv and foward to my email I can tell you exactly how everything should be hooked uo, marpltvt86@aol.com. Usually its just a simle issue of relocating a wire or 2
Mar 06, 2011 | LG LHB335 Theater System
I've hooked up the back up camera to the cameras input and connected the power wire to the back up lights. I'm getting power, but I don't see an option for the camera in the menu nor does the camera come...
i don't know exactly what system you are using
from what you stated your saying the monitor is powering up when put car into reverse
but the camera is not coming on
what this tells me is either the camera it self not getting power or ground
u hooked up the video wire between monitor
the camera needs to get power some how it might be the wire that hooks into monitor but i don't think so usually that just the video wire (but depends on system)
i assuming there is one or two more wires on the camera itself that needs hooked up
a power wire
and a ground wire if there no ground wire then frame where camera is mounted to on car needs to be cleaned of all rust and paint
I assumed allot if this don't help you at all please let me Make and Model # of your camera system and i try and help you more
Nov 16, 2010 | Car Audio & Video
Engine misfires when traveling up long steep grades and hignway speeds. Problem happens when transmission downshifts to maintain speed.
Could be a couple of things. Have you changed plugs, or plug wires. Suggest you do if engine has lot of miles. Could be a (the) ignition coil. Take your GMC to Auto Zone, they will hook it to their computer to diognose, for free. It will tell you exactly what the problem is
Jun 04, 2010 | 1998 GMC Yukon
What cause ABS light to come on
it could be several things.
1. your breaks need replaced
2. the ABS fuse needs replaced
3.or the ABS fuse computer is failing.
The best way to find out what it is is to take it to get hooked up to a computer and it should tell you exactly.
Nov 09, 2009 | 1999 Ford Windstar
IN regards to your problem of how to hook up your receiver you have know how many components your hooking up to it and whether or not you are using standard analog(red & white), or you are using digital (optical,coaxial or HDMI). Next you need to decide if you are going to use your receiver for all your video picture. If so you just match video input with your audio inputs plugs on the back of the receiver. Then monitor out of receiver to TV.In regards to hooking up you computer to your stereo you need to take audio out of your computer(where speakers are currently plugged in) and plug that into an open slot on your receiver youll need an audio cable that has a headphone plug to RCA ends I picked video 3 on mine because I have nothing plugged in there and just ran monitor out of my computer to the TV.
May 27, 2009 | Pioneer VSX-D108 Receiver
Trying to hook verizon UM150 card to verizon wireless DSL Gateway
the UM150 wireless card goes into the computer.
however, the DSL need to be wired to your computer for initial configuration.
if you just hook up the DSL as verizon say, then you will have a open wireless network, anybody can get access to your network.
Feb 03, 2009 | Verizon Communications Ethernet/Wireless-G...
2 Wire Modum and Brother 4 in 1 fax
I have this exact printer for home use. Here what you do.
Plug one end of the Cat3 cable ( standard phone cable ) into the modem and the other end into the 1st port to the front on the left side. Then follow the instuctions in the manual to set up the fax service. Its basically asigning your fax name and number from the menu button.
I hope this helps, if ya need more assistance please post here.
Nov 14, 2008 | Brother Multi-Function Center MFC-240C...
Hot tub wiring
this has nothing to do with computer speakers. it is a hot tub wiring problem...
Jun 22, 2008 | Audio Players & Recorders
Open Questions:
See all Pioneer VSX-D810S Receiver Questions
Pioneer VSX-D810S Receiver Logo
215 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
