Question about Acer Aspire 5520-5908 Notebook
Keyboard broken on my Acer Aspire 5520
How do I remove a keyboard on a Acer Aspire 5920
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
On my Aspire 5520 I had to remove the battery and remove 3 black screws first then was able to pry the plate off.
Posted on Jun 28, 2009
    Scholar:
  • 89 Answers
To remove the keyboard on a laptop do the following:
The piece of plastic that the power button sits on can be removed, you will see a notch in the plastic on the far right of the bar.
Put a flat head screwdriver in the notch and carefully pry upward. this will lift the plastic bar from the computer and give you access to 3 keyboard screws. you cannot miss them, when you remove the screws lift on the keyboard, then the keyboard will be removed from the system.
Just watch that you do not pull to hard and rip the keyboard connector that sits on the system board.
Posted on May 27, 2009
How to switch on wifi acer aspire 4710z
look on a on sign. or on the keyboard left side..
Apr 28, 2011 | Apevia White Keyboard for Acer Aspire 5520...
How do i replace my keypad on my acer aspire 5920 laptop
hi
you have to remove the panel which is found above the keyboard. the two small speaker is found just under that. there is no screw, take something falt, like a screwdriver, pull and it will come out. you have to open the screen 180 degrees.
once that panel is removed you will see 3 screw which hold the keyboard, remove all screws, lift the keyboard slowly, u have to remove the data cable connected to the keyboard, which is found just under the keyboard
hope this will help you
Oct 24, 2009 | Acer Aspire 5920-6727 Notebook
Key board problem
It would seem that the keyboard may be defective. It is a fairly standard keyboard layout, so SHIFT-2 should produce the @ sign. It looks to be a fairly cheap fix:
http://cgi.ebay.com/New-Keyboard-for-Acer-Aspire-4520-5315-5520-5720-5920-_W0QQitemZ390088823197QQcmdZViewItemQQimsxZ20090901?IMSfp=TL090901179007r413
Sep 18, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer aspire 5920 keyboard replacement
http://www.gadgetsmanual.com/aspire-5920-series-users-guide.html THat should be whatcha looking for. Good luck!!
Oct 15, 2008 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5520-5908 Notebook Logo
2,017 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
