Question about Samsung TXP2675WH 26" TV
Keeps turning off and on
My tv keeps turning off and on once you turn it on
    Genius:
  • 1,224 Answers
Stuck key or a signal is interupting this system from in or out the home
Posted on May 20, 2008
TV keeps blinking off
Open it up and check power supply ( regulators ), could be capacitors ,
Check for
Flyback Transformer
and surrounding components.
Aug 15, 2012 | Zenith Televison & Video
I am trying to get the code numbers for Dynex tv
Unfortunately the user manual does not have a pre-programmed code for Dynex, so your best bet is going to be performing a code search.
To search:
1. Make sure the TV is on
2. Point the remote at the TV and hold down "CODE SEARCH" for at least 3 seconds, until the red light lights up solid
3. Press the "TV" button once and the light will blink once, then return solid red.
4. Press the On/Off button repeatedly until the TV turns off (go slowly enough that you don't keep pushing on/off after the TV turns off)
5. Once the TV turns off, press the ENTER button and the code will save (and the red light should go off)
This may take a while, so be patient, but if anything should get it working with your TV this will be your best bet.
Aug 25, 2011 | Innovage Jumbo Remote Control
TV KEEPS TURNING OFF AFTER A SECOND OR TWO AFTER BEING SWITCHED ON. bottom left hand red light keeps flashing red once tv goes off? any thoughts? dave@fruitheads.com.au
Power supply needs repair or theres another circuit fault causing the tv to go in protection mode and shuts down....
Your tv needs servicing at your local repair shop........
Nov 03, 2009 | Televison & Video
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Codes for Big Button Remote
If it's an Innovage brand Jumbo remote, try this...
There are 2 different versions of the Innovage Jumbo remote, an old and a new.
For the old version:
1. You have to have the TV or DVD turned OFF.
2. Then, you have to push CODE SEARCH button once for 3 seconds till it lights solid
3. Then press TV (or DVD) button once till it lights once and turns solid and press the ON/OFF button very slowly and repeatedly as many as 300+ times to wait for the TV (or DVD) to go on.
4. Once it goes on...STOP and IMMEDIATELY press ENTER before you pass up the code or you'll have to start over!
This is very frustrating but my advice is to take it slow and methodical. Think the tortoise and the hare...if you go too fast, you'll redo it several times because you'll keep passing it up and accidentally turn the TV on and off suddenly and miss the code.
For the newer version:
1. Turn the TV (or DVD) ON.
2. Press CODE SEARCH once and it blinks.
3. Press TV (or DVD) once and it blinks.
4. Press ON/OFF button only ONCE.
5. Wait as it automatically searches for the code by itself. It will have a slow long blink between each code it searches.
6. Stay alert because when the TV (or DVD) goes off, you IMMEDIATELY have to push ENTER to lock in that code before it goes onto the next one. (which it will even if the TV is off)
Apr 16, 2008 | Big Button TV Universal Remote
Innovage Jumbo Universal Remote
Dec 30, 2007 | Televison & Video
Samsung TXP2675WH 26" TV Logo
188 people viewed this question
Jerry Greenberg
Jerry Greenberg
