Question about NRS Air Pro Air Hose 1/4 X 50' It's What The Pros Use!
No air to hose on air compressor
Ingersoll-Rand ra330e20 Rand 4000 3.3 hp air compressor. I get 120 psi in the tank but I can't get a reading on the guage to the hose or get any air to the power tool. Is there an adjustment or fix? Or do I need a new pressure guage?
  • Anonymous Mar 26, 2014
    Please advice of the spec. of pressure transducer 39853791 for ingersoll rand air compressor.
  • 234 Answers
Check to make sure that the regulator is set to the proper setting. You need to turn the knob clockwise to increase pressure. This is opposite of a valve which you turn counterclockwise to open.
Post a comment so we know how you did.
Thanks,
Tim
Posted on May 27, 2009
Why does compressor push oil through air filter when it shuts down ?
Minimum pressure check valve is bad. when unit shuts down air pressure goes back thru compressor and pushes oil out the air filter.
Jun 02, 2015 | Ingersoll Rand UP6-20-125 120 Gallon...
I have an ingersoll rand 30t model 253 compressor 80 gal tank. what should the start and stop pressure settings be? what is the run time to fill tank and cycle off?
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Jul 09, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
I have an ingersoll-rand upright compressor model 2545k10-p, 10 hp, 120 gal, 175psi compressor, and the electric motor will run for about 15-20 seconds and then automatically shut off, and be really hot....
Does the motor rotate the compressor or just set there and hum? How old is this unit? Overload heaters may be to small or unit may be single phaseing. Is there air pressure in the tank when this happens.
Oct 15, 2010 | Ingersoll Rand Stationary Air Cooled...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Can the psi be adjusted to lower than the preset 125 psi?
Not that I have read up on. But if I remember right you can go to IR home page and get a number to call a tech or even order a book on it.
Jan 30, 2010 | Ingersoll Rand UP6-25-125 120 Gallon...
NRS Air Pro Air Hose 1/4 X 50' It's What The Pros Use! Logo
357 people viewed this question
Top NRS Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
 Kenneth
Kenneth
Are you a NRS Air Tool and Compressor Expert? Answer questions, earn points and help others
