Leaking Water & Sqeaking
Have a 10 yr old GE top load washer. It is sqeaking loudly and now leaks a good amount of water from the bottom while running.
    President:
  • 1,902 Answers
Main seal has gone bad and needs to be replaced. It might be worth it to you unless you are a mechanical person that you either have a company repair this part or replace the washing machine. The part is fairly cheap but the job is somewhat difficult. You can order the part at repairclinic.com
Posted on May 27, 2009
    President:
  • 1,185 Answers
The drum water seal has cracked or split and has allowed soapy water to get into the support shaft bearings.
The soap has killed the lube and now the bearings are running in rust.
No easy fix , exchange unit will be available from the maker but you need to look at the rest of the machine before you commit to a repair.
Afte 10 years the other compoents will be just as worn as the drive train
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
Amana ALW480DAW top load washer 9 yr old
You're not done yet. The washer pump probably is leaking. Lots of basements being pumped out in this area as a result of the snow.
Jan 16, 2018 | Amana ALW480DA Top Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Sep 19, 2006 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
