Question about Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48
Everything works fine, except when the compressor kicks in the panel breaker trips.
Every time the compressor kicks in, thecircuit breaker trips.
  • Dennis Boxerman May 11, 2010
    This could spell trouble.
    Do you have a multi meter and are you somewhat comfortable with electricity? If so, we can do some trouble shooting. Nothing dangerous, mind you. So don't be nervous.
    Guru:
  • 1,524 Answers
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
Posted on May 28, 2009
Is there a reset on a Holiday chest freezer
Check the thermostat, defrost timer and compressor overload one of them could have been damaged by the surge.
Oct 17, 2014 | HOLIDAY 5 cu ft Chest Freezer White...
Frigidaire upright freezer ice forming in bottom and leaking not freezing ice cream
This does not sound good because the breakers tripping may indicate a compressor windings short. Have someone do the test below,
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Feb 07, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
Tripping breaker
Hi, this is not a good sign when a unit trips a breaker. I can tell you whats causing this without having you check every thing on the unit. The compressor has gone out and drawing what we call locked rotor amps. This is what happens when one fails, it is the only part on the unit to draw enough amperage to trip a breaker. To confirm this, you can pull the unit away from the wall and unplug it. Remove the lower panel that will expose the condenser fan motor and coil, and the problem compressor. On the side of the compressor where the wires go into it, you will see a metal strap that is hooked around a black terminal cover. Remove it by using a screw driver lifting one end off. Now the cap will pull straight off. You will see a small round overload relay there and it just sets there with a metal clip that holds it on. Remove it also and it will have a blk wire attached to a compressor terminal, that is marked C for common. You will have 2 more for the other terminals, R for run, and S for start. Just pull them off. Tape the ends of the wires up so they don't touch anything and don't worry where they go as this compressor will be done. After you have done this, Plug it in and set the control to cool. Everything now should work as far as light and fans, and the breaker will not trip with the faulty compressor out of the circuit. It would be much cheaper to buy a new or good used unit then to replace this compressor. This has to be done by an expert on this kind of unit. It was probably shorted to ground a internal burn out. Sorry to give this news to you, but this happens. Keep me posted on what you have done.
Sincerely,
Shastalaker7
Mar 14, 2010 | Freezers
My copressor won't start. relay works fine in
HAVE YOU TRY A 3-N-1 COMPRESSOR BOOSTER|? YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE THEM. TELL THEM THE SIZE OF YOUR FRIDGE AND COMPRESSOR AND THEY SHOULD BE ABLE GIVE YOU THE RIGHT ONE. FOLLOW THE INSTRUCTIONS ON THE 3-N-1 AND CONNECT TO THE COMPRESSORS. BUT CONNECT THE TWO BLACK WIRES TO A EXTERNAL POWER(GET AN EXTENSION CORD AND CUT IT, WIRE NUT THE TWO WIRES TOGETHER). PLUG IT IN, IF THE COMPRESSOR KICKS OFF, YOU HAVE A BAD COMPRESSOR. IF IT RUNS WITHOUT KICKING OFF, THAT MEANS YOU ARE NOT GETTING POWER TO THE OVERLOAD RELAY TO TURN KICK ON COMPRESSOR. CHECK YOUR TEMP CONTROL INSIDE FRIDGE, AND THE DEFROST TIMER(MIGHT BE STUCK IN DEFROST)
Jan 24, 2010 | Amana Freezers
Condensing unit terns off but won't come back on kicks off breaker
If it runs, turns off, then tries to restart and kicks breaker, look for bad start components. Check start relay, start capacitor. It may be trying to restart too quickly and the compressor over amps and breaker trips. The system needs to have at least 3 minutes of off time before trying to restart. This allows the pressures in the system to balance enough so the compressor can overcome the high side pressure and start. I've seen where people turn the control up and down very quickly causing the compressor to over amp and trip breakers and over loads.
Hope this gets it for you.
Oct 22, 2009 | True 19 cu. ft. / 538 liter Commercial...
Once in awhile, Circuit Breaker Trips
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Apr 22, 2009 | Frigidaire Freezers
Breaker tripping?
It looks like your compressor is the problem , you can try to put a starting kit if it doesnt work you will have to change the compressor!
Francois
Nov 14, 2008 | Freezers
Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48 Logo
283 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
mike cooper
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
