Question about Car Audio & Video
Wiring a sony xplod xm 504z amp
Need help wiring
zzedly
  • 300 Answers
SOURCE: sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Posted on Apr 18, 2008
  • 14 Answers
SOURCE: wiring diagrams
Look here: http://server4.nodevice.com/down/3a1657608f40b3f62b18e5416ded9ec7/xm-zr607.pdf
Posted on Dec 07, 2008
welcomejee
  • 10594 Answers
SOURCE: need wireing diagram
Click Sony Support to download wiring instructions of XM-502Z amplifier.
Posted on Apr 26, 2009
  • 18 Answers
SOURCE: sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Posted on May 27, 2009
  • 149 Answers
SOURCE: I need a high level input connector for a Sony Car Amplifier
best buy-wal mart-circuit city-ultimate electronics-radio shack- any stereo shop that deals with car audio-hope that helps look to spend between 12 and 35 dollars
Posted on Jun 19, 2009
I got Sony Xplod XM-ZR704 700W 4/3/2-Channel Car Stereo Amplifier and 12" sub. it play good for continuous 2 hours but after that starts tripping and goes on off. i checked all wires and connections.
Amp is probably over heating. Make sure the ohm load of speaker is good for that amp. This amp is not really built to handle a bridged 2 ohm load. Make sure ground wire is clean and tight to the body chassis.
May 18, 2012 | Sony Xplod XM-ZR704 700W 4/3/2-Channel Car...
How do i hook amp to a factory stereo
you can bua a conversion kit that ties into your speaker and alows you to hook up a set os coaxl wires to it
Sep 26, 2009 | Sony XM-504Z Car Audio Amplifier
How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod xm 200gtr
Either You Fired Your Amp Or Wires, If You Got The Money Replace The Wires, Also Trying Grounded Your Ground Wire To Something Else.
Jun 09, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod amp(XM-1652Z ) power/protect light
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod Amp
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 11, 2008 | Sony XM-504Z Car Audio Amplifier
Car amps
important is to hav correct wires and groud cable...
Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
743 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
