Question about Hunter 20531 Vista Brushed Nickel Ceiling Fan
Possible remote control problem
The remote has a feature that dims the light on the fan.  The remote still turns on all the fans speeds, turns fan on and off, but the light kit is stuck on dim and the remote button for that will not change anything.
Any ideas??
Thanks
Have you tried holding the dimmer switch for 16 to 20 seconds?
Posted on Nov 04, 2007
Synchronize MinkaAire Remote Control Fans
use two remotes. one fan is in the reverse direction and other forward and it is easier to use 2 remotes.
Jun 02, 2018 | Dryers
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
How to use remote on ceiling fan id m8crl 103
Press the light button and bottom green button at the same time the lights dimming feature will work!
Mar 09, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
Hi my control will completly work fofr the fan, but with the light it will only dim it and make it bright it wont turn it off from the remote, only by pulling the chain or the master switch i can turn the...
Possible that the ,main unit has a fault as the control signals are not processed. You will need to confirm your remote to be working fine specially with the light switch ON and to brighten up.
If the remote is not working check the pads of the remote.If not the fault can be the main unit possible failure of the SCR/Thyristor or a possible control unit..
Oct 29, 2010 | Hunter 52" Ceiling Fan With Light And...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Hunter 20531 Vista Brushed Nickel Ceiling Fan Logo
321 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
