Question about MSI NX6200-TD256 GeForce 6200, (256 MB) Graphic Card
MSI 6200 will not properly install
Will MSI GeForce 6200 run under ME?
Installed new geforce 6200 pci graphics,onboard graphics out,no graphics
Go to control panel then device manager then eliminate the drivers for your old card and the new one as well restart computer. Run the driver install if prompted to do so. Hope this helps
Jan 12, 2014 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
How do i install geforce 6200
Hello! You must first shutdown your computer. Open your cpu and connect the video card on the agp slot of the motherboard. Make sure it is properly seated. Return back the cover of the casing. Connect the vga cable of your monitor to the vga connector of the video card. turn on the computer. The operating system will automatic read the new found hardware. Now try to download the driver of the video card this will give the video card its properties to change its resolution sizes and graphics output. The download site can be found here, just enter the code you see from the image and click download.
Jun 10, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
My driver cd not installing video drivers on windows 7 for the geforce 6200 say xp or vista
You can go to the evga website and download the windows 7 Drivers.And install them . the web site does have windows 7 drivers for that card.
May 16, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
EVGA GeForce 6200 512 MB card + mouse pointer
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Jan 06, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
BUT,
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
EVGA e-GeForce 6200
http://www.evga.com/support/drivers/default.asp?switch=2
Try downloading and installing this one
May 27, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Vedio controller GeForce 6200
XFX GeForce 6200, Graphic Card
driver dowunload
Aug 16, 2008 | XFX GeForce 6200 Graphic Card
Getting black screen after booting screen after install of new card. . :(
hi im wesley iv had the same problem before with my compute. the problem might be i broken ide cable or a loose connection make sure the all cables in your pc is connected properly and if so change a few of the cables if it doesnt work you might have to get a new hard drive and also check if your cpu is in properly and not moving around at all then go into your bios and check the temprature pf the cpu and try running a health test from the bios it might be you fan isnt making proper connection with the cpu causing it to over heat and automaticall switching off for safety.
Jul 08, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
MSI NX6200-TD256 GeForce 6200, (256 MB) Graphic Card Logo
67 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
